Cars & Trucks Logo
Posted on Jul 27, 2008
89 s10 blazer help
We just bought my sister a 89 chevy s10 blazer 4x4 and just changed the battery i just changed it and had my sister start it up and there was still no power so i took the battery off and got the corrosion off and while i was doing that my sister decided to take out the fuses and check them and when i put the battery back on it had power but would not actually start up it would just roll over could there be some fuses missing and it did run when we bought it and we drove it like 70 miles before changing the battery and was turned off and back on
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1076
Points
Have someone check the starter/solenoid
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1264
Points
6
This is the solution junk it i got a 89 s10 blazer and have nothin but problems with is
I have 89 Chevy s10 automatic 4x4 4.3Lt. Want to convert to manual trans I have a 97 s10 4x4 4.3Lt. Manual trans will it fit in my 89 s10 4x4
They will bolt up. You may want to get the wiring plugs off the 97 t case as they will be different from yours. Or use your old t case
My 1986 chevy s10 4x4 truck transfer case is not engaging and the lights for the 4x4 is not indicating anything.i changed the contral switch and nothing. anything else i could try?
I had a 1987 s10 4x4 and put a new battery in it and the 4x4 quit. turns out the vacuum control is right behind battery. listen for sucking sound and see if it is loose on yours.
1988 chevy s10 blazer 4x4 , 4x4 will not engage , changed most of the vacuum lines and still nothing ... aggravated
Have you checked the vacuum actuator under the battery? Battery acid will leak down and cause all kinds of issues with them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
4helpful
3answers
1991 Chevy S10 Blazer 4.3 4x4
4170636.jpgThis is all I've got.Hope this helps?
2answers
1helpful
89-98 chevy blazer
It's not worth doing all that conversion, buy the time you spend the time and money to convert the 89 4.3 to work on the 98 blazer, it would be cheaper to install a 98 vortec rebuild. The 89 4.3 have a TBI fuel injection system and the ecm on the 98 will not work and the bad news is that the ecm on the 98 also controls the transmission shift points and the 89 will not, so even if you swap the ecm to have the 89 4.3 engine work. the transmission will not shift. Sorry for the bad news but it would be cheaper to replace the 98 engine with the years of 1996 to 2001. Good luck and hope this helps.
2answers
Location of oil filter on 89 s10 chevy blazer
look at the drivers side rear of the engine next to trans
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
