Question about Hampton Bay 24002 Ceiling Fan
My fan is blowing, but if i put it on high it does blow fast like it normally does.
  • mineral02 May 11, 2010
    is this a ceiling fan?
    has it always done this?
    how do you switch to high?  use a pull switch?
    how old is the fan and how often have you switched to "hi"?
    --mineral02
  • 75 Answers
The connection order would have got reversed low speed connection has been given to high terminal and high speed connection has been given to low speed terminal thats y this problem this is nothing to worry
Posted on Jul 29, 2008
Pioneer 74txvi fuses (fast or slow) burning
If there is nothing left inside the little glass tube, it's a fast blow. A slow blow fuse will usually have a spring and some other material that make up the slow blow mechanism. slow blow fuses used to also have 'SB' stamped on the metal end caps. The fuse holder may also tell you. If you cant figure it out, put in a fast blow and see how long it lasts, If if blows when you turn the volume high, you should try a slow blow.
Jan 22, 2015 | Pioneer Audio Players & Recorders
IS IT NORMAL FOR THE FUSE TO BLOW WHEN A HEATING ELEMENT DIES IN THE FAN HEATER IN MY ELECTRRLUX COOKER?
The heating element is shorting out and causing it to blow the fuse
Aug 25, 2014 | Ovens
Can i use another 4a 250v fuse for my cerwin vega LS12 if its not a (slow blow) ,and what would be the outcome
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Oct 23, 2013 | Cerwin Vega LS-12 Speaker
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
2000 buick regal blows high fan fuse as soon as it is put in with car offf
I would disconnect your blower motor resistor then try fuse again, if it does'nt blow then it is either blower motor or resistor,these resistors are common for going bad/and or blower motor. Good luck let me know if you need more info or if this didn't fix it, I will research it more for you
Jan 03, 2012 | 2000 Buick Regal
Fan blows high speed and computer wont start
How long havew you had the present motherboard in your computer? if over 3 years (and used on a dayly basies more then likely, your motherboard is in need of replacment because the capasitor/s are leaking (not giving the proper voltage to start and hold your computer at proper levels
Jan 14, 2010 | Dell Optiplex GX280 (99301) Motherboard
A/C only from center vent. Heat from side vents and floor vents.
sounds like the blend motor from hot to cold is stuck open half way allowing both temps to come into the car.
Aug 24, 2009 | 2003 Jaguar S-Type
99' Escalade a/c front vent blows cool air an rear blow cold air.
i have the same problem, my rear a/c blows great very cold, the front a/c blows but it is not cold at all. I had the the a/c seviced and it was vacumed and correct ammount put back in, no problems, the front still blows but it is not cold, i have checked everything and the a/c guy said it might be the door not opening. any help? still not working
Jul 13, 2009 | 1999 Cadillac Escalade
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
