Question about Refrigerators
Maytag Refrigerator Model MFI2266AEU After dispensing a large quantity of water, the control panel has locked up. The light for Water and for Ice are not on; Cannot operate other features on the control panel either. This model does not have a Lock/Unlock control button that I can find. Can you help me Unlock the control panel so I can dispense water and ice again?
  • CaptMagnov Apr 22, 2009
    I have the same exact refrigerator and the same thing occurred. I was filling a 1.5 qt bottle and almost to the top, the panel beeped and the water stopped. Now I cannot adjust any of the settings on the control panel, like Door Alarm, or Temp Alarm, and I cannot select Water or Cube. If I hold the power button, it does shut down the cooling system, but other than that, the control panel will not respond.
SOURCE: Not dispensing ice cubes, only crushed
Yup, do like I did. Clean the caddie of all ice cubes. Place a large water catching tray under the door, and run hot water from the inside where the the caddie holds the ice. You will see large chunks of ice that was freezing up your cube maker. After a couple of glasses of hot water pouring through the caddie, it will defrost and the frozen part will be released. Take off the caddie, and run water through it from your sink. Clearing all ice debris. Replace the caddie. Do not use for 24 hours, and it should run beautifully. Mine did that before it froze up and I cleaned it. You should probably take the caddie off every couple of months and run water through it to keep it clean of frozen debris, make sure its dried off well and put it back, wait overnight. and it should be ok.
This is what I did, hope it helps.
Posted on May 31, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
SOURCE: Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Posted on Mar 30, 2011
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
I have a Maytag refrigerator MFI2266AEU about 7 years old. The ice and water dispenser do not work as well as the controls. What might be the problem?
Basic diagnostics: make sure there is water supply line running to the unit and has water. If this is the case check to make sure the water supply line isn't crimped and is charged (has water pressure). If this is the case look for line blockage in the internal lines of the fridge. Make sure that all fuses are intact, there are no ground faults, and there is power to the control board. Make sure all ribbons are in tact and there are no breaks. Check for water damage on any of the sensors or other electronics which could be kicking fuses or internal breakers.
Jan 28, 2015 | Maytag MFI2266AEU Refrigeration :...
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Dispenser Panel locked out
If you replaced the front control board your issue may be your water tank. How long after you filled your bottle did it stop working?
Mar 01, 2014 | Maytag Refrigerators
Door Panel Locked
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerators Logo
297 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
