Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
I need help tv plasma phillips
Hi i have a problem with this tv plasma When we turn it on, it will not display a picture...it blinks 4 times where the on/off light is....we called best buy & they said it was the (SSB, Small Service Board).
Manufacturer: PHILIPS
Model: 42PF7220A/37
42inch
    Genius:
  • 1,139 Answers
Hello gruponapa,
This problem is linked to a power supply issue. The SSB is part of the power supply chain and will cause system failure if the board is defective. I have seen to many of these type of modular power supply boards fail. The shutdown circuit is detecting excessive voltage, and in the process of turning off the set it may have blown something else. I am begining to suspect a design flaw, which happens from time to time. I would suggest having a qualified TV repair person take a look at the TV and work on it.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 27, 2008
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
If that doesnt take care of your problem then the problem is with the main control board. or ssb
Aug 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Lg 50px4d-eb
I have one here next to me when I pushed power the green LED started blinking until it brought up the picture 1 blink per second about 8 blinks. i am on the tuner input it may vary on different inputs also if it blinking like 1 blink pause 4 blinks or some pattern like that that is tech diagnostic error codes. if the tv is working you should be able to get a menu or on screen display even without an input attached. Also I only heard 1 relay click in the back
Jan 19, 2008 | LG 50PX4DR 50 in. Plasma TV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
