Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana refrigerator not getting cold
Our Amana ABB1921DEW refrigerator doesn't get cold in the top refrigerator compartment, however, the freezer works fine. There is no cold air coming in any of the vents. The damper functions and the vents are not blocked. There is frost on the rear of the freezer. When I run service test 1,"Defrost Thermostat and Defrost Circuit test" I never see the "0" under the refrigerator keys that indicate an open circuit and the freezer keys that allow this selection on the test do not operate. Also, when I short the circuit the frost on the rear of the freezer compartment does not melt. This leads me to believe the defrost thermostat isn't working. Would a malfuctioning defrost thermostat cause no cold air to enter the refrigerator compartment? In addition when I run troubleshooting test 2 "Compressor/Condenser Fan Test", I can't hear any fan. Should I hear this fan or it just really quiet? Is this bad, too, or will it just not operate when the defrost thermostat is malfunctioning?.
  • 2 more comments
  • renneke Aug 30, 2008
    Frost build up on coil in my freezer, no cold air coming up into the refrigerator. Freezer bottom unit gets super cold, ice cream like a block of ice,
  • amanaprob Feb 12, 2009
    same problem freezer too cold fridge not cold enough. need answers asap. please help. buildup of frost over vent in back of freezer.
  • tee_sc Mar 11, 2009
    I have model abb2227dew same problem. Frost buildup on vents in back and now air coming up through vents in frig
  • Anonymous May 22, 2009
    same problem, very frustrating since this isn't very old and I don't know is it cheaper to fix or buy new???? Does anyone have this answer yet?
  • 314 Answers
SOURCE: my Amana refrigerator isn't cooling
check if you have ice or frost in the back wall of the freezer if yes the defrosting system is not working
Posted on Sep 04, 2011
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Macmarkus
  • 2605 Answers
SOURCE: I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
Posted on May 08, 2010
heatman101
  • 43501 Answers
SOURCE: No cold air to refrigerator; extra cold air to
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
  • 183 Answers
SOURCE: I have a Amana fridge that the evaporator fan is
There may be damaged or broken wire to the evaporator fan
There are two wires to the evaporator, one hot and one neutral Unplug and check the neutral against ground with a continuity tester if ok test the other wire in a non invasive fashion using a safety pin
The way you do is to insert the pin say at several points on the wire until you discover where the break is. Use alligator clips, one is to be connected at the connector of the fan hot wire ( The suspected wire that may be broken) With alligator connected at the end of the wire connector, insert the pin at different points to check wire integrity with an ohmmeter. Where there is no continuity, that is where the break would be.
If that does not work, you probably will have to run a new wire. Here is a hint: The evaporator fan runs only when the compressor is running. If you can extrapolate, you can find an alternate way to reconnect the evaporator fan and have your fridge running in no time.
Posted on Dec 20, 2010
Amana model TL20KL Top Freezer having condensate dripping from freezer compartment thru vents in top of refrigerator compartment.\r\n Could be a leveling problem. Unit tilts toward front and the Unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 29, 2011 | Amana Refrigerators
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Jul 28, 2009 | Amana ARB2257CSL Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 16, 2009 | Amana ABB1927DE Bottom Freezer...
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana fridge
is the freezer cold. the freezer is acualy the only refrigeratted compartment . it has the evap coil in the rear wall and a fan to cerculate the air . a potion of the air is let into the food compartment . most comonly the freezer defrost system can be the fault. so i would requier answers to the first question. is the freezer compartment working. hope this helped
Oct 19, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
2,828 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
