Kitchen Ranges Logo
Anonymous Posted on Feb 21, 2011
Bottom coil won't heat up, but the top one does when on broil. There are no codes on the control panel. What could the problem be?
Sal De
Level 3:
  • Frigidaire Master 2,699 Answers
  • Posted on Feb 21, 2011
Sal  De
Frigidaire Master
Level 3:
Answers
2699
Questions
0
Helped
1003214
Points
8029
You'll have to check the element with a meter to see if it's bad,umplug the machine,remove the screws that hold the element in,slide it out,remove at least one of the wires and read it out with the meter,alot of times you can see a burn mark or a break in the element,if the element is good,look for a broken wire in the back of the unit or the clock could be bad,again you'll have to check with a meter to see if you're getting 240 volts down to the element,be careful you have to do this with the power on.next time send the model number.the only way to tell is get in there with a meter.
YouTube - Range Bake Element Replacement (part #316075104)
  • Sal De Feb 21, 2011
    YouTube - Range Clock Control Replacement (part #316557100)
1 Related Answer
Anonymous
  • 215 Answers
  • Posted on Nov 10, 2009
SOURCE: I have a Frigidaire range Model # FEF351CWB. When
This means that the bottom heating element is burned out and need replacing, yes you are correct the top will come on when the knob is in the broiler position.
Bottom of oven does not heat properly
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter.( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advicebcuzGod is so good!
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges,the oven temperature sensor
is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test.
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
I have a Frigidaire range Model # FEF351CWB. When you turn the oven on for Bake the top and bottom coils do not heat but when you turn on Broil only the top coil heats and the bottom doesn't.
2helpful
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
9helpful
Where do i put my wood chips? under the heating
Buy some lava rocks from your local hardware store. Get just enough to cover the coil with 1 layer of rocks. This will help control and retain the heat produced by the coil. Now, just throw a couple chunks of pre-soaked wood on top. I recommend hickory or cherry...never mesquite, it is way too harsh for slow smoking. Happy smoking!
No heat on the upper oven bake and broil elements
I gather you are measuring voltage with respect to the chassis ground?
http://www.appliancepartspros.com/07-wiring-information-parts-for-maytag-cwe5800acb.html
Shows the internal wiring for the unit. The parts are rather expensive and some are no longer available.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
