You
can download owner's manuals and installation instructions for
several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid,
Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here. Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it
here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need
this service.
You can find links to helpful exploded view diagrams and part ordering help
here.
I recommend that you bookmark that link to your favorites.
Hope this covers it.
William E. Miller
[email protected]
http://www.microwavedisplay.com
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
