Just got a 2 wire modem. The linksys wireless connect to the modem, but the internet doesn't work. i don't get a default gateway address? any suggestions?
Try with a shorter enet cable and see if you get internet, if you are able to get internet with a shorter cable then the cable might not be working fine. Else get a wireless card installed on your computer since the 2wire modem has wireless connectivity. It would be more easy and convenient to connect to wireless using the 2 wire modem.
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Its possible that the linksys adapter is not setup properly, or it does not have the same wireless settings set on your 2wired wireless modem. Do you know if the network form 2wire has a security. You can checkt he site survery tab of your linksys monitor.
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
