Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Is it dead?
My whirlpool Ultimate Care II top loading washer fills with water and then nothing. Currently it is full of water. I applied pressure to the lid in case it was not recognizing it was closed but no luck. It doesn't make any sound or perform any functions except filling with water. It is plugged in and the GFC has not tripped, I checked. Please tell me I can fix it.
  • 2 more comments
  • ztipsb Jul 28, 2008
    I have the same issue. I used a hose to drain the water out so it doesn't start to smell.
  • o2 hauler Aug 01, 2008
    Get a pencil and hold in the button on the door. If that makes the washer start then you need to put a new switch on the door latch.
  • tktmom03 Aug 29, 2008
    My Whirlpool washer, three years old, is filling and then NOTHING....it won't drain, spin, wash, it's useless. What is going on? ANYONE?
  • datuna07 Aug 31, 2008
    I have the same problem. Filled with water and now will do nothing. I tried the pencil thing, did not help. Before it died, I did smell a burning smell. When I turn it on, the lights in the room dim a little, but machine does nothing. Could this be caused by running a medium load on a small load cycle, although 2 loads were done after that?
I did the pencil thing, you can hear a buzzing, but no movement...
Posted on Sep 08, 2008
  • 22 Answers
Your machine needs a new lid switch
Posted on Aug 22, 2008
The washer does not stop filling with water at the chosen water level, small, medium, full etc
your water level pressure switch located inside the control panel is defective,there is wires and a plastic hose to this component,replace it and it will again fill correctly
Mar 19, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool ultimate II water level problem
does it still fill when you unplug? if it does then the fill valve is no good.if it turns off the check your hose going to pressure switch.will be a small clear hose going from tub to your pressure switch.
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool, top-loading Ultimate Care, 20 lb washerm
The ticking sound is coming from the drive motor.
Removing the back and peering into the guts will tell you if there is a shredded belt causing the problem.
If the transmission has failed, the last one I bought years ago cost ~$130 wholesale.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
