Question about Acer Computers & Internet
3680-2682 ACEER ONCE THE COMPUTER TURNS ON IT ASKS DO YOU WANT TO START WINDOWS NORMALLY...YES IS THE ANSWER...THEN IS STARTS CONFIGURING UPDATES...THEN IT SHUTS DOWN...THE PROCESS CONTINUES. I LEFT THE COMPUTER ON ONE DAY FOR ABOUT 4 HOURS AND IT CONTINUED TO CONFIGURE AND SHUT DOWN. WHAT IN THE WORLD IS THE PROBLEM????? PLEASE HELP ME.
  • 981 Answers
Well, you type in all-caps, that's bad.  As for the computer, you have discovered the wonder that is Microsoft Windows Update; it does in fact take that long.  As such, your problem should have been categorized as a Windows __ problem, where I'm kind of hoping __ is XP.  You should say which!  Does it not start normally and without prompting you after 12 hours of that?  (And yes, there are ways around it; but you should read a book or two on your OS if you want to save time.)
  You should check around on microsoft.com and technet for articles on configuring win.cfg in the Windows directory if you're still getting the prompt.
Posted on Jul 27, 2008
    Scholar:
  • 81 Answers
Hi Teeortay,
Here are the possibilities:
1) Hard drive has too many read element failures
or
2) windows system files needs repairing or operating system needs re-installation.
Try these:
1) Reboot your pc and get into BIOS. Then set to default setting and save. Then try booting. If this does not fix issue, take next step.
2) Insert the operating system cd and go thru the repair process.
This should fix your issue and good luck.
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My laptop wont come on a screen keeps coming up asking to repair or start windows normally i have tried both without success
When was the last time you were able to use your computer?
Did you installed any software recently in your computer?
Try pressing F8 on startup and use the Last Known Good Configuration. May be that will help.
Feb 28, 2011 | Toshiba Satellite Laptop L655S5150
COMPUTER WAS TURNED OFF IMPROPERLY. TURN-ON WAS IN SAFE MODE NOW EVERYTHING IS LARGER AND BLURRED
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
always click APPLY after making any changes
don
Feb 02, 2011 | Computers & Internet
When I turn my computer on, it asks for safe mode or start windows normally or last configuration. No matter what I put in it does not boot up; it kind of keeps looping.
I could be caused by harddisk failure since it cant boot properly anymore.
Try running your Window installation cd. Once it boot the cd, choose Repair option.
Mar 29, 2010 | Micro Electronics PowerSpec 8250 PC...
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
When i turn on my laptop it goes to start windows normally or last known good configuration but when i select one it goes right back to start windows normally page again
Insert your OS system disk or recovery disk. reboot computer, boot from DVD, start installation of software, do not repair from the first prompt when asked, click install, once windows searches for previous version of windows click repair. This will reinstall the system folders and straighten out any registry problems. once complete you are done.
Nov 30, 2009 | Acer Aspire One AOA150-1784 Netbook
My computer starts up perfectly fine, i click the " start windows normally" button, and it loads. Then after loading the screen turns black ( I can still see the LED light and cursor) PLEASE HELP!
When it ask you how you want to start the computer the select Last known Good Configuration. It should boot up normally.
Then go o the control Panel - System - Hardware - Device Manager and check for any devices that didn't install (the ones with the yellow ?)
You will need to reinstall these drivers.
Apr 18, 2009 | Compaq Presario PCCOM2232US Notebook
When I switch on Acer Aspire 5315 get message "Configuring updates 3 of 3 0% complete" for a few second then pc shuts down restarts and goes back to the same configuring updates message just...
try starting the computer in safe mode. As the computer boots keep pressing F8 until you hear a beep. The computer will or should start in safe mode, once it has everything will look big, don't worry about that for now, click on start>programs>accessories>system tools>system restore and choose a date for when you know the computer was working without any problems. Once the computer has restored it will shut down and reboot. When/if asked what mode you want to boot/start your computer choose start windows normally. I hope this helps.
Oct 22, 2008 | Computers & Internet
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Laptop won't comeback on
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
Computers & Internet Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
