Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Kp53hs30 light flashing 6 times
The timer standby light is flashing 6 times no picture or sound help
  • 1,139 Answers
Hello worksofgrace,
I gave this advice earlier, but since your problems is just about the same, I hope this helps.
This problem is linked to a power supply issue. The SSB is part of the power supply chain and will cause system failure if the board is defective. I have seen to many of these type of modular power supply boards fail. The shutdown circuit is detecting excessive voltage/current, and in the process of turning off the set it may have blown something else. I am begining to suspect a design flaw, which happens from time to time. I would suggest having a qualified TV repair person take a look at the TV and work on it.
Thank you,
Posted on Jul 27, 2008
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Power comes on, red light flashes on timer/standby but no picture
Need the model number of your set and also how many times is the led blinking? Please respond to this same post
Jul 25, 2008 | Televison & Video
Timer Standby light flashing No pitcher
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
