Question about LG 24 in. LDS 5811 Built-in Dishwasher
IE Error - stressed motor
We got and IE error after having the dishwasher for 3 years. IE is stressed motor error. Luckily my father is an electrician and we had LG send him a free control board (since that was still under warranty). We just replaced the control board and so far so good! So, don't waste $ on a repair man, just order a new control board and install it and you should be good to go! Let's see how long it lasts before something else goes wrong since it is LG junk!
  • dzbum411 Feb 02, 2009
    IE is not inlet error according to LG Customer Service. This solution posted is incorrect. IE is stressed motor and we repaired the problem with a new control panel.
  • tamus1 Mar 07, 2009
    My LG of a year and a halfe just broke down again. Now it has an IE error. I cleared it and it hasn't come back bot now it takes a very long time to wash the dishes. A 2 hr.and 15 min. cycle takes about 4 hours. I opened the frount panel like for the LE problem and fixed 6 wires. 2 hanging by just 1 or 2 streads. Still no luck. Any one else have this problem and maybe the fix?
  • LG Master
  • 19,396 Answers
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Posted on Jan 31, 2009
  • Ginko
    Ginko Feb 02, 2009
    Well my solution was taken from the service manual for your model, published by LG.
    If you check on the internet you find only two page referrening to stressed motor, and hundreds referring to inlet error or input error.
    In your case the error was a faulty control, if it was stressed motor you wont fix it by replacing the board. That is the reason why replacing the board fixed it.
    I will be grateful if you can modify the negative rating given.
    Thanks
    LG Dishwasher -IE Error
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
How to fix lg dishwasher that has code le
I think you may be getting IE code which relates to water inlet problems. Either the water pressure is low or the inlet valve may not be working properly.
Refer page 21 in the user manual which can be dowloaded from this site
Product Support
But if it is LE code then see this page for suggested fix.
LG Help Product Support and Troubleshooting LG USA
Jul 30, 2014 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
Blanco dishwasher error d06 faulty motor.
I have a Blanco BFD10X Dishwasher which had the same D06 error, being a Electrician i investigated the fault which Blanco report as motor over current. After testing the motor, i tested the motor Run capacitor and found it to be faulty, these capacitors are common to failure and will cause the pump to draw more current than usual.
A genuine replacement 2.5uf capacitor was quoted at $120.00, however i purchased a equivalent from RS online for $14.30 + delivery. RS P/N 769-4267
Dishwasher working fine again.
Nov 15, 2011 | Dishwashers
IE error in the middle of washing it seems to stop and the motor sounds labored.
LE error code means the motor is resritcted or locked up. you can try to clean out the sump area but will most likely need to replace the Wash Motor
Sep 12, 2011 | LG LDF6810ST Stainless Steel Built-in...
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
LE error code
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
Jun 21, 2009 | LG LDF6810 Built-in Dishwasher
Error code LE
If you are getting a "water inlet" error "IE" I found out thru trial and error that my inlet valve(s) were messed up. On my particular machine you can put the machine in trouble-shooting mode by pressing the "Spin Speed" and the "Soil Levels" at the same time and press the "Power" button while doing that. Then advance thru all the functions by pressing the "Start button"
1 time; Tumbles clockwise,
2 times Low level spin,
3 times; High speed spin,
4 times Inlet valve for prewash,
5 times; Inlet valve for main wash,
6 times, Inlet valve for Hot water,
7 times: Inlet valve for softner,
8 times; inlet valve for bleach,
9 times; tumble counter-clockwise,
10 times; turns Heater on (if equipped)
11 times; circulation pump,
12 times; drain pump,
13 times; power off and unlocks the door
Good Luck!!!
May 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Ldf 7811ST dishwasher
ok if that's the correct code then it will likely be a communication problem between the motor and control panel ie loose wire broken wire resistance on the touch pad control ribbon which can be cleaned with a pencil eraser by the way or something along those lines the control just thinks the motor is bad because it cant communicate with it maybe
Mar 23, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
373 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
