Broken connector in subwoofer connection on receiver
How do I remove the broken piece of my monster RCA cable that remains inside the subwoofer connection of my receiver? Or, is there another output channel I can use for my subwoofer from my Pioneer VSX-91TXH Elite receiver? My subwoofer is an Infinity, powered with low level input for left and right, and high level left and right (which I've never used)
  • corisha Jul 27, 2008
    I was able to remove the broken connector and plug the cable into the subwoofer connection on the receiver, however, I'm not getting any sound from the subwoofer. The green ready light is on...but no response when I play a blu ray movie. Any ideas?
    I was able to vacuum out the broken piece. thanks! But, the subwoofer is not responding now. Do I need to reset something?
  • 3 Answers
Opened my pioneer vsx 49txi when my subs stopped workig it look like the solder connection broke free from the circut board is ths expensive to fix?
Posted on Feb 13, 2009
    Genius:
  • 1,011 Answers
Dear sir/madam,
Take all that bulk cable and turn it into something useful with a connector kit. Or replace a broken connector instead of buying a whole new cable. you're not supposed to try and pull them straight off. Instead, twist them clockwise while firmly (but carefully) pulling straight out. They'll come off with no problem.
thanks
good luck
"Don't forget to rate the solution"
Posted on Jul 27, 2008
    President:
  • 624 Answers
The problem you now have can be one of two things most likely. One is, the RCA jack on the receiver has some broken solder connection causing no output from it. Two, the Pioneer receiver is not set properly with the sub-woofer output activated.
You can check the sub-woofer output to see if it is activated thru the menu system.
The solder connection being broken would need to be checked visually by removing the board the sub woofer RCA jack is on.
If both of these do not work for you or you can not do it, then you can try hooking the sub-woofer up differently. The only other option for you would be, to connect the subwoofer with the speaker level outputs of your receiver from the front "A" speakers. Get some speaker wire and connect them directly from the receiver "A" speaker output and run those speaker wires into the speaker wire inputs of the sub-woofer. Then you should have a speaker wire output from the sub-woofer to run to the 2 front speakers that were connected to the "A" speakers previously. That way you have volume control over the sub-woofer when you use the volume control on the Pioneer.
There is another way to connect this, but you would not have volume control over the sub-woofer with the Pioneer, only thru the sub-woofer gain control. That would not be a very good way, but you can do it by connecting the RCA jacks from the sub-woofer input to the TAPE REC output of the receiver. You could at least do this so you can check and make sure the sub-woofer is working properly.
You most likely have some broken solder joints on the RCA output of the Pioneer, since you had a broken RCA connector stuck in it, it would be likely that it also broke the solder connection on the board where the RCA jack is connected.
  • Dave DeGain
    Dave DeGain Jul 27, 2008
    By the way, you can not reset this receiver by unplugging it for 30 minutes. You would need to unplug it for about a week or two for it to reset. It is not like many other types electronic equipment where unplugging it will reset the unit.
    It has a capacitor in the circuit for the micro that stays charged for at least a week or more even after unplugging it. This capaitor is used like a battery in the micro's circuit and is of suficient value to keep the memory settings with the unit unplugged.
    Go ahead and try to reset it by unplugging it, you will notice that the tuner will still be set to the same station after you plug it back in. That is proof that it did not reset. After a reset, the tuner will be set at some random frequency, not the station you left it on when you unplugged it.
    There is no reset procedure for this model, the only way to reset it, is to be able to do a hard reset on the micro. This means you must ground out the supply voltage momentarily at the micro, or to force the reset pin on the micro to change states from it's current state.
    I work at an authorized Pioneer service center and I actually fix these type of units every day, so my knowledge of this type of thing is pretty extensive.
  • 1,183 Answers
As per the user manual , the receiver has only one sub-woofer connector. The other alternative is to use the digital audio output for the speakers . That would mean either you have to change the speakers or get a conversion box that would connect your analog speakers to the digital output.
The other thing that can be done is to replace the sub-woofer connector. The same can be done by a radio repair guy or you can take it an authorised pioneer repair centre.
Thanks
proton
source:http://hometheater.about.com/od/avreceiversreviews/gr/piovsx91txhs.htm
  • 2,071 Answers
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Jul 27, 2008
    Click for the sample video,when it open ,the SX-580 what
    inside and the VSX-LX50 demonstrating how to use the connection,if your Pioneer VSX-91TXH Elite receiver has an extra composite video connection,you can connect there..
    Pioneer
    SX-580 repair
    Pioneer VSX-LX50 HD Receiver Video
    http://www.doorone.co.uk/xGS-Pioneer%252...">Pioneer
    Repair
  • LORETO LACARON
    This the picture of your Pioneer VSX-91TXH Elite receiver ,there is a three screw side by side six all in all.
  • LORETO LACARON
    Yes its better you reset the unit unplug the unit for 30 minutes and re plug again...
if you are mechanically inclined you can take the cover off the receiver and use a paperclip. Bend the paperclip to an "L" shape. Puch it in the terminal from the inside to expel the broken prong, then reclose the case. If not try a strong magnet such as a mechanics pick up tool
Dec 26, 2011 | Audio Players & Recorders
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Trying to connect powered subwoofer
Try setting the speaker settings on the receiver to small.
Jan 12, 2009 | Pioneer VSX-D511 Receiver
How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Dec 16, 2008 | Yamaha YST-MSW10 Computer Speakers
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer connection
    if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
    Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
    2,230 people viewed this question
     Grubhead
    Grubhead
