Question about Philips HDD1630 MP3 Player
Lockup when connecting to PC
My HDD1630 locks up whenever I connect to my PC via USB. When I try to repair using the device manager, it tells me that it failed to repair and to reconnect the player. Any ideas?
  • 8,596 Answers
"Failed to repair" = the player is donel anytime this player is connected to a computer running Vista or Windows Media Player 11, it's days are numbered - Philips has a warning on their website, but most people don't see it in time
This is too bad, because Philips no longer has any of these in stock
Posted on Aug 14, 2008
I have windows 7 and a pretty stock sony vaio VPCEH12FXB laptop and for some reason my webcam wont work. whenever i try to open it or use oovoo it just tells me that my webcam is either not connected or in...
If your webcam worked before this problem then you probably have a hardware issue. The webcam is installed on your LCD display panel. This is connected to the system board via a cable. It's possible the cable became dislodged from the webcam or the system board due to opening the LCD display to use the laptop.
Go to device manager to see if the webcam appears in list of devices. If not then
you will need to have the laptop repaired by Sony or competent repair shop.
Sep 28, 2011 | Sony VAIO EH1 Series Black Computer...
Please connect player to pc
You have to run a Repair in the Philips Device Manager - that is the solutino to the problem. If the repair fails, your mp3 player is toast - call Philips to see if you are in-warranty.
-Tha Mp3 Doctor
Jan 25, 2009 | Philips HDD1630 MP3 Player
Philips 6gb mp3 player
Run a repair in the Philips Device Manager
Aug 16, 2008 | Philips HDD1630 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
My computer don't found my mp3
The HDD1630 is only compatible with Windows XP and Windows Media Player 10.
If you have Windows Media Player 11, unistall it to roll back to version 10.
Install and run the Philips Device Manager from the product CD.
Connect the HDD1630 to the power supply and connect to the PC.
The MP3 player should show as an MTP device. There should be a connection icon on the player screen.
Start Windows Media Player, and select the SYNC option to transfer music.
Feb 17, 2008 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player about 2 years old, no excessive use, won't charge any more or be seen by computer. Only shows low battery on screen then dies. I am a little technically incline, can anyone tell...
You may have to change the battery, but try Reset, Repair, and Update (firmware upgrade) first. Also, there is an FAQ on the Philips website for the computer does not recognize device issue (but only follow it AFTER you have tried reset, repair, and update).
Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
After repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
Feb 05, 2008 | Philips HDD1630 MP3 Player
Phillips Go Gear 6GB
The Phillips website has a solution for this:
Go to the FAQ for this mp3 player. It'll tell you to install the Device Manger which will repair the problem. I've done this, however, the Device Manager claims my mp3 Player is not connected.
Try this yourself, you might have better luck.
Oct 27, 2007 | Philips HDD1630 MP3 Player
"Please connect player to PC"
Go to www.philips.com and download the hhdd1630/17b software and firmware updates. Install them and print off the instructions on what to do. This fixed my player and what a difference it made.................WOW
Sep 11, 2007 | Philips HDD1630 MP3 Player
Philips device manager application
yes you can. go to www.p4c.philips.com Hope this helps!
Feb 01, 2007 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
