Question about Tappan TGF320 Gas Kitchen Range
Stove help My left front burner will not ignite. It makes a clicking sound and smells of gas. I can't raise the top of the stove to attempt to try to clean the elements (pilot etc.), underneath. I have to use a match to light the left front burner. What to do?
  • craftyduo2 Aug 21, 2008
    Front burners light but the back burners do not. When back burner turned
    on gas escapes but does not ignite. Can be lit with a match. Cleaned
    stove well and vaccumed to try and remove any left over dried food etc.
  • tptagth Aug 26, 2008
    I have the same problem.
  • 4 Answers
I'd like to know, too. Thank you for your help.
Posted on Aug 26, 2008
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
The top left front burner will not ignite. The igniter is sparking, but does not ignite burner. You can smell the gas. The burner will ignite with a match.
Hello
This sounds like the tube that runs from the burner to the ignitor is clogged. If you raise the top of the stove, look for that tube, take it out and run it under some hot water to remove the residue buildup. Replace the tube and try it again. My thought is that is the trouble,
Let me know how you make out, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Ovens
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do...
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Dec 14, 2008 | Garland H283 Gas Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan TGF320 Gas Kitchen Range Logo
230 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
