Question about Acer Computers & Internet
Acer PC won't connect to broadband, apparently the ethernet card needs to be re-installed, can anyone help with this?
    Genius:
  • 1,689 Answers
Like with what and how to locate the card you have and get a match for the replacement?
refer to the link below to get the information about the current component in your machine, then let me know what else do you need.
http://support.microsoft.com/kb/308549
Posted on Jul 27, 2008
I have a second hand Acer f1,and want to connect to broadband i have connected the ethernet cable and it is recieving ,but when i click on internet explorer i cant connect to net what do i do next ?
is your broadband live? meaning active
if it is go into device manager on pc your trying to connect with and look at devices to see if your network adaptor is active. If you need help just respond and ill walk you through process
Feb 10, 2013 | Acer Computers & Internet
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
I canot connect to the internet using a broadband some devices are missing, for example the ethernet controller, PCI device, PCI modem...
Hello Friend,
Since the ethernet controller is not installed that means the Ethernet card is not installed and you will not be able to connect via ethernet port. Also if you have wireless, you should install it first to be able to connect wirelessly.
You can try this software "Driverupdaterpro": http://www.ixitools.com/dup/details/
it scans your computer and detect your hardware and give you the best drivers to use.
Best Regards,
Oct 30, 2009 | Acer Aspire M3200 19" 2.5GHz Athlon X2...
Ethernet connection
Yes you can use the Ethernet port/card in your Pc,
your isp should provide the Modem for you for broadband, connect the computer's Ethernet cable to the broadband cable modem.
Your good to go
(( if you have a NIC network interface card ))
in the PC
All is good for you
Regards
Richard.
Apr 27, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
No Local Connection Icon / No broadband connection
Have you checked the Device Manager to see if the Ethernet adapter is even listed, or if it is does it have a warning symbol on it for Ethernet Controller? Use Windows Help to get to Device manager if you are not sure how to. It could be that your Ethernet Controller (Local Area Connection) is disabled in your BIOS as well. Look there to see if it is, or Load Defaults option in BIOS and Save Changes, as that will enable the Ethernet Controller by default if it is working.
Mar 19, 2009 | Computers & Internet
Ethernet controller for Acer Travelmate 2312
browse through the acer panam website in the drivers / service section...
Search Other TravelMate Models and Look For An Intel Chipset Driver, Download and install..
Feb 17, 2009 | Acer Computers & Internet
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
BSNL Broadband connection
In brief yes. 2 possible ways:
1. Use a router; or
2. Configure 1 of your PCs to be the Default Gateway and enable Internet Connection Sharing (this is where the single user broadband connection must be plug in). If your modem uses USB connection to the PC (Gateway), use the LAN card IP add as the Default Gateway of the other PCs in your network. If your modem uses the Ethernet port, you need to install a 2nd LAN card on the same PC and do the same configuration.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
