Question about GE 26998GE1 Cordless Phone
Static problum & battery not working
My phone is giving me a problum # 1 it is always have a lot of noice i try every thing like changing chanel and diffrent jacks not luck. # 2 battery is not holding power any help please a_ali550@yahoo.com
Thanks i will try that & will let u know know what happen
Posted on Sep 03, 2008
  • 79 Answers
Make sure you are in range of the base with no other interfering electrical devices, replace battery if it won't hold a charge. That may be the main issue.
Motorola mr350
I started in electronics 33 years ago and my first job was in LMR;s (land mobile radios). I know they have changed a lot since then but the basic transmitting structure will always be the same. It sounds like something that I have never seen but one or two go bad but on these occasions the Crystal has changed frequency. This is your Local Oscillator and will cause your superheterodyne to run at a different frequency. It would be a constant frequency and explain the one channel. I know if the wrong crystal is put in one and is close enough to even run it can be several channels off. Check this out it is a little far fetched because as I said earlier these things seldom go bad but you never know. If it is a crystal then when you reset it it would reset to the same frequency that it has changed to. It is still working but just off frequency. Let me know how it turns out.
Later-
Mar 17, 2014 | Radio Communications
Sri i hav problemof automatic restarting in my cell phon 5530 pls sen the solutionn somtime network problem is comm problem??
1. Try taking out first the memory card before restarting it and restart it once the memory card is already out. It should be then restarting fine once the memory card is removed. It is not restarting because the Memory card is not helping the phone to reboot or to restart. That's the problem. 2. If it wont start try to reformat the memory card or either have the phone checked out or fixed.
Hope that solved your 5530's problem. Take care always
Dominic :)
Feb 22, 2011 | Nokia 5530 XpressMusic Smartphone
Excessive static equally on all chanels on cb
You should always connect the CB directly to the battery as the accessory socket is full of noise. You also should choose a better antenna as these small glass mounts cannot hear signals well and magnify local noise. AM (CBs) radios naturally pick up noise as it is the nature of AM signals. Use your squelch to lesson this but too much can knock out you reception.
Feb 14, 2010 | Cobra Radio Communications
I have a battery low problem after 1 or 2 hours after charging my n73 battery, i tried to change my battery but the problem is always the same. help me please
just minimise the backlight timing, make off the screensaver, switch on the power saver, don't switch off/on the phone, and most important don't overcharge and put ur phone on charging whenever it shows low battery alarm and remove as soon as possible as the battery is full, your battery will give you more backup.
Jan 29, 2010 | Nokia N73 Cellular Phone
My nail gun makes a small noice but will not shoot. The battery is charged but it is not doing any thing. The first thing it did before it quit was worked fine for ten nails. Then it just made a faint...
I know a lot of Dewalt nailers will not shoot properly once the battery is starting to get a little worn/has a lot of charging cycles on it. Their picky about having fresh batterys. How old is the nailer/batterys?
Dec 13, 2009 | Black & Decker 16GA Finish Nailer Kit
When I hit the on button for a dialtone it just keeps blinking and then shuts off. Sometimes if I keep at it, it will stay on but the Static or shwisshing sound is like something out of a Stephen King...
ok it sounds like there may be a battery problem.
if there are chanel buttons try changing chanels.
if not you may need to replay the battery.
Nov 13, 2009 | Uniden Cordless Phone
I think the heads on my G2L needs replacing. Strips appear when I record. Clean heads and it works for a few recordings.
Head have two parts-uperdrum and lowerdrum. Lowerdram is part which is static, and tape are passing on him,with his own chanel. You need to erase road of tape on the begining chanel untill the end of chanel.In that plase,usually we have a lot of dirty. It`s nessery to erase whole road of tape ( the part where tape is moving ) and whole mehanic. This will help you if mehanic of camera didn`t work a lot.( ex. 2000  hours ) Don`t forget to wote! :-)
Nov 13, 2009 | Canon GL2 Mini DV Digital Camcorder
KX-TG2632 causing static to my baby monitor.
Baby monitors apparently are all on 2.4GHz frequency range. Phones have to be either beneath ie 1.8GHz or above eg 5.4GHz and no interference will occur. So simply had to change the phone because its frequency range was 2.4GHz.
May 27, 2009 | Panasonic KX-TG2631 Cordless Phone
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
RCA H5400 Cordless phone
Lots of static when I turn it on. Changing the channels does not work. Having no onother appliance plugged into the outlet doesn't work. Moving it away from other appliances doesn't work. What should I do?
Dec 22, 2007 | Panasonic KX-TG1033S Cordless Phone
GE 26998GE1 Cordless Phone Logo
75 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
