Question about Sony Playstation 3 (PS3) Console
PS3 doesn't appear on screen. Possible power issue.
Whenever I turn on my PS3, it turns on fine, but nothing appears on the screen. I tried switching a/v cables, but nothing worked. Thats when I noticed that when I turn it on, only the green light turns on. Is this a power problem, and if so can I fix it?
  • 1 more comment
  • Anonymous Mar 30, 2009
    mine does the same thing it powers up but only the green light is on and there is no picture on the tv
  • leahrodgers7 Mar 30, 2009
    I have the same problem.When I turn the system on the sony entertainment screen comes up.Then the screen locks up and it turns all different colors.
  • Anonymous Mar 21, 2014
    Upon switching on, the green light comes on for 20 seconds and then turns off...nothing i do can get the screen to switch on...how can i fix this?
  • 344 Answers
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Posted on Jul 27, 2008
  • Wes Sydenstricker
    Wes Sydenstricker Jul 30, 2008
    This is NOT a power problem. You didn't even give that much info. The green light is SUPPOSED to come on when it's powered on!!
Use sloution 2 and hold the red button until it turns green then to red then start it works[=
Posted on Mar 04, 2011
Your the bomb that worked thanks
Posted on Sep 19, 2008
Gamefixer you do not help at all!
Posted on Aug 21, 2008
  • richy rich12 Mar 04, 2011
    look at solution2 it fixed my ps3 right up
PS3 turns on but nothing comes up on the screen/no sound.
First thing to try is a video reset.
While the PS3 is off (red solid light) hold down the power button until you hear the SECOND beep, quickly release the power button.
Let me know what happens.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
No menu appears when you switch it on only the wave and colour appears also will not turn off have to turn off from main switc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
No video or audio
Well i would not call it normal if there is not screen no sound this would be due to a hardware failure at this point.
You need to have a sony expert look at the unit for you to find out what went wroung and what can be done if anything ot the unit to put it back into operation.
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
PS3/TV Video Problem
HI, this is an issue that concerns the main board. there is a integrated video card that is used to render the graphical information. there are some issue there with the internal connections. you will need to send this unit to Sony for this repair.
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 turns on but does nothing!
this probably can be a problem with your Hard Disk . try using a new one (borrow it from a friend, for example) , or try formatting yours in a PC (notebook) platform .
else, you can try an advanced cooler cleaning. for this, do it :
  1. Turn the system off by the switch that's behind it .
  2. Turn the switch you powered off ON while you HOLD THE EJECT BUTTON .
  3. It will make your coolers work in maximum speed for a while, this must set the system free from dust . (i don't think that's the problem).
else, contact Sony Support Center for possible hardware issue checking (maybe there's a problem with RAM units)
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on, my background screen appears but nothing else loads, not even the numerous areas (Settings, network etc.) all that appears is an icon in the upper right hand corner saying "Press the...
you can try doing this cuz i had the same problem till i did this...Access the PS3 recovery menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Turn power on with a steady green light but nothing appears
Try it on another TV if nothing shows up then your PS3 or the video plug is broken.
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
No picture any more
if your tv has a light blub replace it this is only for hdtvs
May 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
718 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
