Question about Danby DAC8003D Air Conditioner
Water indicator light always blinks
Our air conditioner has been in for service every year, it has been operational for 3 weeks and now the red water full light is constantly on, the air conditioner does not run, the dehumidifier does no run, the fan does work. We have drained the bottem plug, we have drained the overflow plus, we have removed and replaced the side tank, we have removed, drained and replaced the main tank.
How do I fix this PLEASE
Very frustrated
    An expert who has answered 500 questions.
  • 540 Answers
Internet or email... check the water levelswitch or better yet go straight to the horses mouth! Thank-you-very-much!
Posted on Aug 27, 2008
Red light and beeping on danby air conditioner dpac120068- what does that mean
Hi There,
If you have check and emptied the water bucket, the problem could be the water level sensor. Please contact our customer service department to be connected to a technician who can assess the unit. The office hours are Monday to Thursday 8:30-5pm and Friday 8:30-4pm. The phone number to call is 1-800-263-2629
Thanks and have a great day!
Jul 27, 2012 | Danby Heating & Cooling
When i turn it on, the fan runs for a minute then shuts off. the red light blinks 4 times then a 5 second pause, blinks 4 times, then pause and so on and so on
Please always write with models and brand name. to solve your problem at once.
With your details, it means Float switch Open circuit (High level water alarm).
Drain pan full of water and dusty. Clean it by dis assemble the unit. Call qualified repairman.
Jan 04, 2011 | Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
When i turn the hot water tap on to get hot water the red pilot button keeps going on off and clicking , after some time runing hot it goes cold and the other warning light starts flashing. its a...
Air conditioners do not provide hot water, and gas air conditioners are very rare. I think you would have better results if you post this in a different category.
Jul 27, 2008 | Heating & Cooling
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
Danby DAC8003D Air Conditioner Logo
199 people viewed this question
Top Danby Heating & Cooling Experts
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
