Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki model number f450maf
I can not turn on the machine because once i turn it on it will short somewhere
  • 828 Answers
If there is an electrical short in the machine it may very well be the compressor that has failed, burnt out or internally shorted. You need to call a service tech.
Posted on Jul 29, 2008
Hoshizaki troubleshooting
Need entire Model number. usually ends with a number. Serial number would help too.
Jul 17, 2014 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice stuck need longer harvest time
need model number to really help. generally, if you turn on the number 1 and 2 dip switches on the control board, it will give you the longest possible defrost.
Sep 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I need a new part for Hoshizaki Model # KM-500MAE. Help!
Rick at Restaurant Parts and More can get Hoshi parts. Just have model and serial numbers. He takes credit cards. Usually can it parts in about 3 days to your door.
Aug 02, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My ice maker 10amps fuse burn out when turn on the machine
This may sound too simple. A fuse is a safety. It usually blows when the amps are higher than the fuse rating. Since yours blows immediately, I would look very closly for a pinched wire, a crossed wire, or a wire that has rubbed through. Once that is eliminated, start isolating components one at a time. Check their web site. It's pretty good. Also, their tech support line is pretty good. It's worth the wait. 1-800-233-1940.
Jan 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice Maker Model F450MAF make less ice.
water valve is leaking. repair valve or replace.
May 22, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Model F450MAF
cheak the machine hot gas line solenoid valve is problem or HP side air block
Hoshizaki Ice Machine starting problem after shut off
I am guessing there is a safety switch somewhere which is gauging how much water is left in a defrost tray. Other likely things: open circuit breaker from the water shorting things out. Start with these. Other, more exotic things could be involved...but not as likely as the above.
Dec 04, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Waterpump of Ice Machine KM-500MAH-E
Always attempt to have Hoshizaki pumps rebuilt when possible. The parts are cheap compared to buying a new pump. Check ebay from time to time I have just started tearing units down and selling the used parts, that are still functional. Sold that pump for $75 last week
Nov 06, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
112 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
