Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Turn signals wont turn off
I had to replace speedo sensor recently,
now turn signals no longer shut off automatically.
know nothing about modules
help please ,too fragged to remember to turn off in day time duh
  • Anonymous Sep 16, 2008
    SPEEDOMETER DOES NOT WORK AND TURN SIGNALS WON'T CANCEL
  • bcbuch Oct 06, 2008
    I have a similar problem. My speedo is working fine but cruise won't turn on and signals dont cancel. I have checked the brake, clutch and throttle iputs to the cruise module and all work propoerly.
    Could this be the speed sensor? Would the speedo work if the speed sensor on the trany were bad? 2001 Road Glide.
Could be the turn signal module itself but it could be the speedometer also. there is a white/green wire from the speedometer going to the turn signal module, block the bike up and run in gear, turn on the blinker and check for a signal on that wire. there is a reed switch in the speedometer that will send the signal for the turn off. this is a sealed instrument so you will have to buy another one.
Posted on Aug 13, 2008
    Genius:
  • 2,028 Answers
This could be a loose connection, or the signal timer relay has gone out.
Posted on Aug 06, 2008
Speedo not working, turn signals not cancelling replaced speedo sensor
Hi, Harold and the usual suspects are:
1. Contaminated or faulty speed sensor.
2. Faulty turn signal module.
2. Corroded, broken or loose connector pins/sockets in the wire harness between the speedometer and the ECM or TSSM and the sensor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Speedo and Auto Cancel Turn Signals not Working Harley Davidson Forums
Harley Davidson 2003 Dyna Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak to me personally absolutely "FREE"
Jul 14, 2017 | 2001 Harley Davidson FXDWG Dyna Wide Glide
2001 ultra classic turn signal module replacement
Hi, Rocky picky, picky, picky you realize of course that the electronics on this machine came out of a Boeing 747 and is interfaced with the space shuttle's diagnostic backup system, "BUT" the vast majority of speedometer issues is caused by the speed sensor and or the wiring, a faulty speedometer sensor and or connection will automatically interrupt proper turn signal and flasher operation. On Sportsters the sensor is located on top of the engine case behind the rear cylinder, on big twins, it's located on the right side of the transmission case between the starter end cap and the transmission top cover. Remove the bolt/screw that secures the sensor and lift the sensor out of the case. Inspect it for damage and contamination, if there appears to be no damage wipe the end of the sensor clean and reinstall, you can go for a short quick test ride to see if the speedo is working. If the issue still exists grab your test light and unplug the harness connector from the sensor, check for power (red wire) and ground (black wire) continuity coming from the speedo, there is also the connector that plugs into the speedometer, also, look for corroded, broken or loose pin/sockets. If everything checks out OK then replace the speed sensor. For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or answers at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day
2009 Harley FSXTC Speed sensor removal and replacement part
Harley Davidson Touring Models Workshop Service Repair Manual 2001 $9 cheap
Instant Tech Relief To speak with me personally absolutely "FREE"
Mar 08, 2017 | 2001 Harley Davidson FLHTCUI Electra Glide...
05 elantra 2.0 auto speedo dont work replaced all 3 sensors and body to eng grd is my cluster bad or drive gear bad help please how do i replace drive gear in trans help
If i may ask why did change the sensor,did it show the the ABS light on the cluster?You need to perfom a cluster self diagnosis am not sure of the procedure on Hyundai since i am a Nissan Tech or perfom active test on the cluster,if not check the fuses.Back to sensors if you had an ABS light before and it cleared but still no Speedo then you might have bought wrong sensors,the ABS module can tell that there is a sensor due to resistance but as you drive it can't pick up your speed signal to the ECM
Apr 11, 2015 | 2005 Hyundai Elantra 2.0
Speedometer not working.
No it does not. The speedometer uses the VSS (vehicle speed sensor) This goes to the ECM then the instrument panel,the transmission control also uses this sensor
Mar 08, 2012 | Saab 93 Cars & Trucks
Speedometer stoped working and turn signals won't
Your turn signals will not shut off automatically if the speedometer is not working. As for why the speedo is not working, I'm afraid I can't help you with that as I know nothing about them but I'd check the speedometer sending unit in the transmission first. It's supposed to generate a pulse for the speedometer. I work on the older bikes that the dealers will no longer work on and some Evolution powered bikes. I do not work on the digital electronics nor fuel injected bikes. I'm sorry I can't help you more.
Good Luck
Steve
Sep 17, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have the same problem with my 2000 v70 glt a not only does the break, abs, and check engine lights come on and the speedometer and odometer don't work but the arrow starts flashing and the vehicle seems...
The most common problem is with the ABS control unit. You will most likely have to replace it. It is located under the brake hydraulic unit (not the master cylinder). This part can be purchaced from a Volvo dealer, or sent to one of the many places that repair them. If you choose to fix it yourself, and would like the name of one of the companys that repair them, let me know.
Nov 23, 2010 | 1999 Volvo V70
Speedo ,auto shut off for turn signal not working and wont idle
bad speed sensor is why speedo and the auto turnoff for signals not working
Oct 01, 2010 | 2003 Harley Davidson FLHR Road king
2005 Ultra Classic ,Speedo Cuts Out Which In Turn Cuts Out Cruise Control, And Turn Signals Wont Shut Off,And At Idle Bike Engin Will Stall,But Will Start Up . This Is An Intermiten Problem
I believe the turn sigs, speedo and cruise are all controlled in part at least by a module under the fairing. It may need replacement or it could just be a loose wire. Sounds more like a loose wire plug or bundle, if intermittent.
Jun 10, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
665 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
