Question about Microsoft Xbox 360 Console
Can,t setup wont take ip #
Cant get xbox live to accept ip number
  • Anonymous Dec 06, 2008
    It won't confirm my DNS test.
Setup xbox live
Posted on Nov 16, 2008
  • 2 Answers =)
Posted on Jul 30, 2008
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
I have a wireless internet connector for my xbox and i cant seem to get it to connect to xbox live. i can get it to read that there is a connection to my computer and the signal is stong but i it wont...
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Dec 23, 2010 | Belkin N150 Enhanced Wireless Router...
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer then make ip address of xbox to perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Open port numbers UDP 88 and TCP 3074 pointing to the IP address of the XBOX. Make sure that the IP address of the XBOX is within the IP segment of the router. Ex. if your router has IP address your XBOX should have 192.168.1.x IP address.
Feb 22, 2010 | NetGear RP614 Router
Cant join parties on xbox live, i tried everything.
make sure you have your router setup correctly. and sometimes it helps to have a static ip address. you can find more info at
Nov 01, 2009 | Microsoft Xbox 360 Console
Cant connect to xbox live
make sure that your xbox is acctually getting an ip address, by default it should be a 192.168.0.xx number and the gateway should be
If however your xbox tells you that its ip address is 168.xx.xx.xx (a private ip address) or if it is simply it would sugest a cabling problem.
However if the network troubleshooter finds no faults and you are still unable to get into xbox live try setting up a PPPoE connection using the username eircom and broadband1.
Alternatively,If you click on Firewall in the Netopia admin page, and set the security level to Low, xbox live would suddenly start to work.
******Also add UDP ports 88 and 3074 if nothing works.On a netopia 3347 you can get this option in the NAT option.U have to enter the port numbers and the service name(xbox).
Hope it works for you.
Apr 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Xbox live
you can set a static ip address to your xbox if it's not detecting it automatically.
in order for you to know what ip address to set, go to the command prompt (for windows xp: click on start, then run, type cmd). when you're on the command prompt, type ipconfig/all and hit enter. tahe note of the default gateway, subnet mask and dns 1 and 2. for example, the default gateway is, you can set your xbox using the ip address and up (note: you just need to make sure that you are going to use an ip address that is not being used by any other devices that are also connected to the router).
hope this'll help you
Oct 22, 2008 | Westell Wirespeed VersaLink...
Xbox live connection: My NAT
its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
post more details of your router and what you have tried.
also you cant go far wrong visiting here
Mar 10, 2008 | Microsoft Xbox 360 Console
Play on xbox live via wireless
First your setup should be, wall (isp) > Actiontec DSL Gateway > Zyxel router > your computer
If that is already setup right, try the ip address of, some routers use this ip rather that
Hope that helps.
Jan 13, 2008 | Zyxel Prestige P-330W Wireless Router...
Xbox live
Hi you will need to either do the following:
1. extend the dhcp leasing function within the router by increasing the time for the lease, usually this is in minutes
2. manually assign the ip address so ud ont have this problem ever again
3. renew the ip address via xbox 360
4. it could just mean the xbox live server is temp down.
good luck
Jan 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
67 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
