Question about Casio Exilim EX-Z750 Digital Camera
Screen black in Manual mode
After initially working fine one day the screen suddenly turns black when in manual mode. It will still take a picture but you cannot see what is on the screen. This happens when you press the record button or if you wait few seconds. However, the screen works fine in the programmed modes. I checked the auto power off and that is still set for 2 mins. Please help as this is the only mode I use.
I had this problem, not sure how I fixed it but I think it had something to do with power saving mode. Check if battery charged.
Posted on Aug 08, 2008
I have a Canon PowerShot SX 10 IS. In Manual mode shows only black screen with icons. In Auto mode everything is fine.
Dear Olia,
Just a quick check on your camera. You have a focus issue so check the settings for the ISO - increase the value, eg. 800 or above and reduce the shutter speed. You can do that by the quick access dial (wheel) facing you. There are four direct access menus in a criss-cross direction. One is assigned to shooting mode - single, multi, timed etc. The other direction will have macro, standard, telephoto etc. the 3rd direction will (towards right) will take you to the ISO settings and the last will take you to the shutter speed settings.
you manipulate the ISO and shutter speed and see your screen will brighten up and the subject will be clear. Refer to the picture attached.
Hope this helps.
Oct 18, 2015 | Canon PowerShot SX10 IS Digital Camera
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Black screen; lens won't shut; totally not working now
Sound like the sensor or recoding electronics are bad. The camera is most likely beyond economical repair and I would buy a new one.
Nov 19, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Black screen on canon a 550
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on or off to save batteries. You would then use the optical viewfinder, just like you've been doing. To turn the screen back on, press the button once more.
Oct 11, 2009 | Canon PowerShot A550 Digital Camera
Black vertical lines & looks like safe mode when XP is loading
ur video card heats to much, so check if the fan in ur video card is working, if ur video card didn't have a fan try to install one
May 26, 2009 | Dell Dimension 4600 PC Desktop
Powershot s410 My s410 is "old" :( but I love it and has been working amazingly over 10,000 photos in the 4 years I've had it. All of a sudden this week-end when I am in auto or manual mode the screen is...
Since it is taking a picture, and showing it up afterwards on the display, it definitely sounds like you activated the DISP or DISPLAY button. Seeing that you've used this camera for years, you should know that this manually turns the screen on and off to save batteries, and to turn it back on again, all you have to do is press this button once more. As you've undoubtedly already tried this, suggest trying the button again, maybe jiggling it (to overcome potential corrosion) to reactivate the screen.
Apr 21, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Cannon Power Shot A560
Did you accidentally hit the lower left "Disp" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
Jun 18, 2008 | Cameras
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
69 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
