Question about Fisher and Paykel Dishwashers
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took over the house. We would appreciate any help you can provide.
    Scholar:
  • 93 Answers
U1 means the unit has failed to prime with water within 3-4 minutes.
Its taking longer than expected to fill with water.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Posted on Jul 27, 2008
How do you fix Error code U1
U1 is displayed on the LCD as a "no tap" symbol. (time out on fill is after 175 seconds)
Possible causes:
• Water turned off
• Insufficient water supply pressure
• Blocked water softener filter (if fitted)
• Spilt rinse aid causing over foam in tub
• Incorrect detergent being used
• Motor rotor
• The machine is siphoning
• Inlet valve has failed
• Controller
Jul 08, 2014 | Fisher and Paykel 23 in. DD603H SS...
I have fisher&paykel.dishwasher.nautilus, half way through the washing,it beeps non stop and shows me U1 . AND IT DOESNT WORK SO I HAVE TO START ALL OVER AGAIN
U1 fault if caused by several things: water supply not turned on (I doubt that), unit is syphoning causing not water in tub to be detected during cycle (this is possible if the drain system in incorrectly installed), spray arm in the drawer is not in place or get moved somehow, excessive foaming (wrong soap or too much), inlet valve failed, controller failed, or rotor not fitted correctly.
I would inspect this issues and locate the reason the unit will not complete the cycle, you may end up replacing the controller in that drawer to fix the problem (as a last resort).
Good Luck
Oct 11, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
After running for a while , about 3 minutes , a red light with the letters UI shows up and the machine stops its process .
Are you sure it shows UI or U1 . To help you check this Fisher&Paykel service manual and find among error codes. The manual is here!
Jun 03, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Error E1
there is no e 1 error in dd603 , maybe u1 or f1 , u can call 1800650590 nd ask hem to send the use nd care manual , or download it from fnd p website ,
If it is U1 its saying taps not turned on , more than likey u have a F1 fault which is a flood sensor error , which means u need a new mains filter board around $50 to buy
Jan 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwashers Logo
1,795 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
