Question about JVC HR-S5902U / HR-S5912U VHS/S-VHS playback VCR
JVC HR-S5902U / HR-S5912U S-VHS VCR POWER PROBLEM
JVC HR-S5902U S-VHS VCR ..... NEED ADVANCE TECH LEVEL STEPS ... NO POWER WHEN PUSHING POWER BUTTON ON PLAYER .. NO CLOCK DISPLAY .. PLUGED IN GOOD OUTLET .. CHILD LOCK NOT ON. I AM AN ADVANCED ELECTRONIC ENGINEERING LEVEL TECH 50 YEARS EXPERIENCE. I want to avoidbuying a "Service Manual"....
Thank You,
Rob Roy, Ph.D
  • ironcrayon Jul 27, 2008
    Thank You,
    Rob Roy, Ph.D
Same problem with my HR-3911U after a power spike. Cracked open the box and as I suspected the fuse had blown. Removed fuse, plugged in and tested across connectors, 115v ac good reading. Replaced fuse (1.25a 250v) plugged in and nothing. The deck electronics had fried. Keeping for spare parts such as head and transport mech.
Time to get a new one and a better surge protector. My UPS logs show a 1200+v spike the day it died. We had storms all around us and thunder in the distance, but nothing close by and no rain, but the spike still made it to our inadequate surge protector.
I've read a lot of forums where other JVC owners have experienced the same problem. It appears to be inherent to these JVC Vcrs.
G
Posted on Jul 30, 2008
JVC HR-S9500 S-VHS VCR. all functions work except the eject on the vcr. there is no eject on the remote.it plays, ff, rew, stops etc. I can't get the tape out.
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Jan 05, 2010 | JVC HR-S9500 S-VHS VCR
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
JVC HR-S9800 UNPLUGGED FOR WEEK NOW WON'T POWER UP
I had a similar problem. I took the top off and wiggled all of the connectors, unplugged and replugged some and it started working. I'm still not sure what the problem was.
Mar 17, 2009 | JVC HR-S9800 S-VHS VCR
I have a JVC HR-J610U VHS VCR cannot set tracking
On the VCR its self hold in the + and - buttons to set the tracking manually.
Mar 15, 2009 | JVC Televison & Video
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
JVC HR-XVC30U DVD Player / VCR
This model is a DVD player not a DVD recorder. Only the VCR can record.
Sep 03, 2008 | JVC HR-XVC30U DVD Player/VCR
Vcr does not respond to tv/vcr button on remote
You will not know from looking at the VCR if it is in VCR mode or TV mode. This is more likely a TV issue of whether the TV is monitoring the VCR or not. Make sure you have the TV selected so that it is monitoring the VCR.
That VCR/TV button has caused more confusion for the average person than anything else.
Hope Ya Fix It!
Jan 22, 2008 | JVC HR-J692U S-VHS VCR
Camcorder to JVC HR-A592U S-VHS VCR
you must select the input in your vhs. usually its a line input (wether 1 or 2). try to find it also using your supplied remote for the vhs. good luck!
Feb 09, 2007 | JVC HR-A592U S-VHS VCR
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
JVC HR-S5902U / HR-S5912U VHS/S-VHS playback VCR Logo
498 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
