Broadcom BCM5705 Network Adapter Logo
Posted on Feb 21, 2011
I get this message "the
2 Related Answers
Anonymous
  • Posted on Mar 31, 2008
SOURCE: The capability of your network adapter does not match the requirements of the network
I was having the same problem with my Dell laptop and Netopia wireless router at home (Windows Vista Business), every so often the laptop was unable to pick up the wireless network. I had an identical router at work and no such problem was ever occuring.
Using the Dell Wireless WLAN Card Utility on my laptop, (Site Monitor Tab), I discovered that another router was broadcasting on the same channel, similar signal strength, I changed the default channel number on the router. This solved the problem.
Anonymous
  • 3 Answers
  • Posted on Jun 04, 2011
To correct this issue visit Device Manager by going to Start, then right click Computer, choose Device Manager. Once you are in the device manager click the + next to Network Adapters. Find your wireless network adapter, right click it, and choose uninstall. Once you uninstall the drivers, right click and choose Scan for Hardware Changes. This will then have your computer re-add the drivers.
tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
Cannot connect to wireless network
Can you post the output of the "ipconfig /all" command?
If you don't know how to do it let me know.
Reset the settings for my 2wire185 on my laptop
You have to go to "Manage Wireless Networks" and delete the network you are trying to connect to. After that you will be able to reconnect without a problem.
1helpful
2answers
Can't connect with the internet. Message is "settings saved do not match the requirements of the network."
okay what you do is go to start documents and copy this to the address bar "Control Panel\Network and Internet\Network and Sharing Center" after you do that click on manage wireless networks on the side now click on your internet profile and hit delete after its deleted search and find you internet and set it up again
3answers
I cannot set up an ad hoc network.. i also cannot connect to an ad hoc network with WPA security type.. it says that the capability of my network adapter does not match the requirement of this...
Recent computer devices are wireless compartibilbles least requiring network adaptors to establish. Ascertain the computers recent innovations also from where enabling the Wi-Fi features capturing available peripherals. For example, ascertain that another device from where networking requires establishment has wireless feature from where computer recognizes. Where each device are wireless compatible would recognize requiring passes to communicate with network structures. In a situation that one of the device has password sets, would require ascertain what entry passes makes connectivity. For example, networked computer already established requires verifying from network administrator to capture another device on the structures. Also, condition where the computer devices are prior innovations would require modems or adaptor devices or routers to complement the network structure or signal sharing. Such a situation requires ascertain the host computers as the administration point from where passwords are distributed to each device peripherals.
1helpful
2answers
The capability of your network adapter does not match the requirements of the network this is what it says when i try to log onto our new wireless router? please halp......
39helpful
9answers
Sounds like driver related problem to me. Re install the driver by using your installation CD, or simply download this tool Driver Update Software for XP Vista 7 8 and make the update. Cheers
Top Broadcom Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Larry Ng
Larry Ng
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
