Question about Whirlpool Refrigerators
We have a stand alone freezer (Whirlpool) and just notices the sides of the freezer are very hot to the touch. Could that mean the coils are not working properly?
    Scholar:
  • 93 Answers
It is normal.That is a portion of a refrigeration system where high pressure gas condensed into a liquid by means of transfering heat to the surrounding air.
That portion is called CONDENSER COIL.
Posted on Jul 27, 2008
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Two sides of freezer very hot to the touch
it sounds like the compressor is going bad or has gone bad
Dec 20, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Front metal piece that the seal goes against - between freezer and fridge
clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 23, 2008 | Whirlpool ED5SHAXM Side by Side...
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
