Curtis Mathis Model CM 19001
Hi. I have a CM 19001 that was given to me without a remote control unit. First off, does this model have closed captioning available on it? If so, is there any way I can turn this feature on and off without using a remote? Unfortunately, I haven't worked in over a year and I cannot afford to buy a replacement remote, so I am really hoping that I can use the close captioning without one.
Thanks for your time,
Jim Lyle
motorcityjim@yahoo.com
Actually, I was able to locate a remote control. So that pretty much took care of the problem.
Jim
Posted on Jul 27, 2008
My remote control dusn*t work, I have bougth a new one from TOSHIBA CORP. ,but it also fail.
As long as the remote is the same model as the previous one, the problem is with the unit not the remote. First make certain that you have nothing that might block the signal between the remote and the unit. Check that the sensor or area where it is located on the unit is clean. If all this fails then you need to have the unit in for service.
Feb 06, 2015 | Televison & Video
My humax freesat model hdr-1000s remote control is not working with the box
If this is brand new call the company support number ASAP. It could be something simple you're doing wrong or it could be a defective remote that needs to be replaced under warranty but you MUST call ASAP to be sure to get the problem in the records before the unit is out of warranty.
Oct 12, 2014 | Televison & Video
Xfinity remote setup
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 03, 2014 | Comcast XFINITY
My tv is a model 27v412t, and i was trying to put the closed caption manually since I lost my remote control and ended up blocking it. At the screen appeared Block on, I tuned off and now it wont turn...
Hello mar...... You will have to either find the remote or replace it as it is the only way to get into the closed caption menu. If you want a replacement factory remote you can go on line at http://www.replacementremotes.com/
Joe
thanks for choosing Fixya!
Jan 05, 2011 | RCA Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
I lost all the tv channels on channel master cm-7000 model and do not understand how to get them back?
First look at the indicator lamp on the front left side.
If it is:
off - check the power cord is plugged into a working outlet.
Amber - the unit is in standby, press the on button (left most), it should turn green
Green - the unit is in operate mode, check the antenna and cable connection.
Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
Jun 05, 2010 | Digi Channel Master/tal to Analog...
My sagem dvr62160sl uk digital reciever wont work
A number of Sagem models have shown incompatibilities with the recent Freeview retune, there is a list of affected models (see http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf ) but it's not a fully comprehensive list. Sagem error code 07 means there's an access problem in back-up memory (stored in the EEPROM) and code 09 means the machine has been unable to find any data necessary to do an upgrade. In essence, your box has tried to upgrade itself and failed and now cannot restore to it's previous state.
Your dvr62160sl is closely related to the dtr6240 and 6280 models which are known to have had issues and so the official advice is to contact Sagem directly on 0845 0900 316 to find out how whether they can supply a solution on a dvd or if they've scheduled an OAD (over air update).
I hope that you've found my posting to be of use and ask only that you return the favour by rating my answer.
Oct 23, 2009 | Televison & Video
HI I HAVE A SATELLITE RECEIVER . THE BRANDS OF MY RECEIVER IS STRONG. IT' S MODEL IS : SRT 4620 I WANT CONTROL IT WITH OTHER REMOTE CONTROL. IN THE OTHER WORD I WANT DO IT WITH THE REMOTE CONTROL OF THE...
Is the remote for the tv programmable? I don't think so. Your going to probably have to get a universal remote and program both the satallite and the tv into it.
Jan 20, 2009 | Universal Remote Control 2700A DTV...
Thomson top up tv remote codes
need sequence to tune in remote controller
May 13, 2008 | Televison & Video
Remote for DirecTV wont control my Toshiba VCR/DVD combo unit
Its true sorry but there isnt any codes available for combos.
Feb 19, 2008 | Directv D10 DTV Receiver
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
