Acer Aspire  T690 (AST690UP820A) PC Desktop Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My acer t690 is shuting down for no reason i think hard drive is going when i buy new 1 can i install and use vista straight away as my pc wont let me burn a copy of the factory default disk wat do i do??????????????????????
Sumit Gajanan Tambe
Level 2:
Guru:
  • Expert 219 Answers
  • Posted on Feb 21, 2011
Sumit Gajanan Tambe
Expert
Level 2:
Guru:
Answers
219
Questions
Helped
21332
Points
355
Press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
no sound
software problem -go2 device manager &under device if u see yelow ? mark so tht driver is missing from my computer REINSTALL IT
Else hardware problem thn Replace speaker
cant access google home page
Andrew Tunnera
Level 1:
New Friend:
  • Contributor 30 Answers
Andrew Tunnera
Contributor
Level 1:
New Friend:
Answers
30
Questions
Helped
3679
Points
76
Sounds like a thermal problem. If the PC shuts down unexpectedly, I would make sure the CPU cooling system is clean of dust especially the fan.
Does not sound like a hard drive problem.
-AAT
My computer is acer aspire acer t690.do you think it is harddrive
it looks like sata
Aspire T690 Specifications
Part Number: AspireT690 Aspire T690
Storage CD-ROM, CD-RW, DVD-ROM, DVD/CD-RW Combo, DVD Dual, or DVD Supermulti (varies by model)
Up to 400GB Hard Disk Drive SATA (varies by model)
9 in 1 Card Reader (selected models)
Where can i get a copy of the operating system for an acer aspire 4720z vista
Its normally stored on the hard drive of the PC in the recover partition of the hard disk drive.
If you've formatted the hard drive without burning a recovery disk, you can try contacting ACER via their web site and ask for assistance. You could buy a copy of Window Vista. But if you decided you need to buy a new operating system buy Windows 7 instead, its much better than Vista.
If however you don't want to buy an operating system and be legal. Then you can download and install one of the Linux based operating systems for free. I like Ubuntu best, but there are others.
Just google Linux or go straight for Ubuntu :- http://www.ubuntu.com/
3helpful
No sound after installing window 7 starter, driver installed with vista do not recognize the drive software.
You must download the correct drivers for audio, video, hard drive and mother noard.
Go to Acer.com and there is a menu system that will lead you to them.
Hope this helps
1helpful
Vista was pre installed on my pc how do i install a clean copy on my hard drive with no disc?? i have an acer aspire t690
A friend of mine had that problem. She contacted Acer and said she did not have a chance to make a backup disk and she needs to re-install the operating system. Within a few days Acer sent her the backup disks.
Just call Acer and ask for it, like she did. If that should not work for you, come back and someone will walk you through to put a copy of your drive on a cd. Hope things work out for you!
Acer Aspire85 wont boot anything
You need to get into Bios Setup when the pc first starts.
I am not sure but I think the F2 key lets you into Bios Setup
The primary boot device needs to be the Cdrom drive.
The starting order for the pc needs to be set to
1st Cdrom
2nd HDD
You should then be able to install Vista.
2answers
Needing Ethernet Controller for Aspire T690
Let me first say that going with XP Pro and not vista is a wise choice. -- try DriverFiles.net
Cd/dvd drivers missing on vista 32 install
The best way to find out if you need SATA or IDE is to open the case and look. If you have gray cables about one-inch wide with a red line on one side then that is IDE. They are parallel cables. If you have anything else then it is SATA which is a serial cable. I have never been to the Acer Website but I know on Dell, HP, etc. they have a place under support and drivers that you can go. Type in your model number and download the drivers. I don't know if you have another computer to do it, but unfortunately if your restore disk do not work then that is where you will have to go...also see if you can contact someone at Acer and find out why your restore disk do not work. I have wiped my hard drive clean and I was still able to re-install the revovery disk.....Hope this helps.
Don't forget to rate this solution before you log out.
Aspire T690 memory upgrade trouble
Check the Acer web site and make sure U are putting in the correct type of DDR2 ram. Even though they are called DDR2, there are different types, i.e. 5300, 5600, etc.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
