Fan runs, but when compressor starts to run, you can here it trying to start up but then falls off and 30 seconds later it tries again and falls off again. It does not kick the breakers out. Duo Therm Quick Cool 15,000
  • rwatson586 Aug 01, 2008
    Thanks,I found a burnt wire on top of capacitor.
  • 143 Answers
The compressor has a safety switch under the cover where the wires connect to it. That's what is kicking out. You should check the capacitor connected to the start winding. Check the wires where they connect to the compressor. A burnt off wire for the run terminal will cause these symptoms. If that's all good, it's being fed correctly on all 3 terminals, the compressor has stalled and will probably never start again. You can try a "hard start" kit, but not on a Scroll compressor (read the label). They aren't designed to survive that.
Posted on Jul 27, 2008
2 Suggested Answers
  • 588 Answers
SOURCE: We have a Duo-Therm 590 quick cool unit on our
Check the compressor capacitor.
Posted on Jun 16, 2009
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
HVAC fan is on, but the compressor attempts but will not start
Sounds like you have a condensing unit that has a lock up condition; commonly known as "Locked Rotor'.
A simple step would be to be sure the compressor is cool.
Start the unit, and as it try's to start, bump the compressor on the shell sideways to jar it , with a rubber mallet.
If the compressor starts... it may or may not start again at one point.
You can try adding a start assist, or commonly known as a Hard Start Kit. It's simple and the two wires go on the Run Capacitor In parallel with the wires with the compressor wires.
Usually the capacitor has a C common ..F fan.... and M motor terminals . The start assist wires piggyback on Common C and M motor. NOT THE FAN side of the run cap.
http://www.grainger.com/product/SUPCO-Hard-Start-Kit-4E240
Apr 30, 2014 | Heating & Cooling
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Compressor tries to start
It could be a voltage problem. Are you using an extension cord, If you are what gauge is it? It should be at least 14 gauge. If the cord is 16 gauge you could have to much voltage drop at start up. Or you could have something else on the same breaker, when it is running and the compressor tries to start your voltage may drop considerably.and the compressor won't start.
Mar 24, 2012 | General Electric APE08AK Portable Air...
When I woke up this morning, the fan on my Amana SCD23VW was running but the compressor was not. I thought it might be in a defrost cycle, but 30 minutes later it was still doing the same thing, and the...
If the fan is running its not in the defrost the fan doesnt run then.
the things that could be the problem are;
the compressor fan is bad so compressor over heats and shuts off
the relay on the compressor is burnt so the compressor wont start
the compressor is bad
i would suspect the relay first..the fan by the compressor secondly and finally last the compressor ..its the least likely thing to go bad
GENE
Aug 29, 2011 | Amana SXD524VW Side by Side Refrigerator
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
COLMAN TSR
3000 Watts is a little short on the power necessary for the compressor to restart. When it compressor starts it may draw 27 amps or more for a split second. 3000 / 120 = 25 amps. when the fan slows down it is telling you the voltage has dropped and it doesn't have enough power. After the pressure has balanced out in the A/C system the compressor can start against no pressure difference.
Jun 16, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
