Question about Microsoft Works Suite 2004 for PC
Brochure making in microsoft works
I am wanting to create a tri-fold brochure but my works only has half fold templates what can i do?? I dont have word or publisher, is there any other way?
  • 16 Answers
SOURCE: I'm using MS Publisher 2007 and pdf creation problem
  1. On the File menu, click Publish as PDF or XPS.
  2. In the File name list, type or select a name for the publication.
  3. In the Save as type list, click PDF.
  4. Next to Optimize for, click Change.
  5. In the Publish Options dialog box, click the optimization in the Specify how this publication will be printed or distributed list that matches the needs of the publication. For example, if the publication will be distributed online and print quality is less important than a small file size, click Minimum size. If the quality of the printing is more important than file size, click High quality printing.
  6. Click Advanced to display the entire dialog box, and select the settings that you need. (Find links to more information on these options in the See Also section.)
  7. Click OK.
  8. In the Save As dialog box, if you want to open the file immediately after saving it, select the Open file after publishing check box. This check box is available only if you have a PDF reader installed on your computer, and if the Commercial Press option is not selected in the Publish Options dialog box.
  9. Click Save.
Posted on Feb 12, 2009
  • 22 Answers
SOURCE: Need design templates for photoshop
http://www.allgraphicdesign.com/templateslayouts/photoshoptemplates.html
Posted on May 09, 2009
  • 20 Answers
SOURCE: need tutorial to make a 3 fold brochure in Qurak
1. Go to: http://www.48hourprint.com/quarkxpress-templates.html
2. Scroll down to the BROCHURES Section.
3. On the 2nd item (Letter Tri-Fold) click on the file folder icon on the end.
It gives you a jpeg & png image file to place inside of Quark as a guide as well as instructions in a PDF file format.
Posted on Nov 18, 2009
  • 15 Answers
SOURCE: I want to print a brochure in word or psd and how
Unless your printer actually prints borderless, you will have to print it on larger paper and trim it down.
Normally for letter size (8.5x11), us print shop folks design with anywhere from 1/8" to 1/4" bleed and print on tabloid (11x17) paper.
If your printer is capable of borderless printing you should be able to do what was suggested by ikkenom.
Posted on Dec 02, 2009
rcw1962
  • 2571 Answers
SOURCE: I have buyed Microsoft Office 2007 student I
Try Open Office, it is free and can open and save in microsoft formats
Posted on Jul 22, 2010
Need help to print brochures
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
Mar 12, 2012 | Office Equipment & Supplies
What is MS Publisher 2007? How to create FLYERS using MS Publisher? How to create BROCHURES using MS Publisher? How to create NEWSLETTER using MS Publisher?
Publisher is a program that makes it easier to make "posters" and "brochures" and "newsletters".
Start the program. Click "New". Click "start a new FLYER", or "start a new BROCHURE", or "start a new NEWSLETTER", to use some of the pre-defined templates that define the layout of your publication (fan-fold, multi-column, et cetera).
Feb 03, 2011 | Microsoft Office Professional 2007 Full...
Using as a printer on 3-fold brochure
From your print menu properties change it from short 2 sided to long 2 sided or visa versa
Apr 30, 2010 | Canon imageRUNNER 5000 Copier
Program won't open
I don't use that program but perhps I can easy your anxiety a little. You won't lose your brochure if you back it up. Without opening the programs you tried to open your brochure in simply go to the file itself that contains your brochure and copy it to a dvd or a portable media storage. Depending on the size of the file you may be able to zip it and email yourself a copy. Now that your work is safe and away from danger you can try to focus on what is freezing your computer. perhaps instead of trying to convert to PDF format you may try the print command. Instead of printing to your printer, select PDF as your printer. When I create a lengthy project, I always save a few copioes on my computer under different names so i have safety nets just in case I mess up. Good Luck
Jan 04, 2010 | Encore The Print Shop 23 Pro Publisher...
Need tutorial to make a 3 fold brochure in Qurak express 7 or 8
Nov 18, 2009 | Computers & Internet
The MX700 will no longer feed from the bottom. It does want to grab the paper but only gets anout 1/8 in and makes a weird noise when trying to continue. Feed from the back is fine. This seems to have...
Ok dont exced the normal paper typeing Like thickness( you need to read your brochure
and check for acceptable thickness and paper class
The bottom is normally a reserve tray for paper
Oct 19, 2009 | Canon MX700 Office All-In-One InkJet...
If you need professionally designed templates for brochures, you can get them easily on Brochure Templates PSD.
This platform would provide you a great collection of brochures with attractive colors and layouts that you can download easily in PSD format.You can take a look at various types of brochure templates available here.
May 09, 2009 | Adobe Photoshop® CS3 Extended Full Version...
Pamphlet on microsoft publisher
There is a template you can download from microsoft for either Word or Publisher. You select new, then templates, and select the Brochures category. They will have the layout for the pages and colums for back-to-back printing for tri-fold brochures. Just select the style you like and download it. The templates may already be installed with Publisher.
Apr 12, 2009 | Microsoft Office Standard for PC
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
Microsoft Works Suite 2004 for PC Logo
627 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
