Computer will not boot up. It is giving a windows 32 error, either file corrupt or missing. I do not have the windows disk to reboot.
  • 99 Answers
One thing you can try doing is taking out your hard drive then connecting it to another windows computer. After you've connected and booted the machine, run chkdisk.
Also check out this website, although you don't have the windows cd, if you have another windows computer this should do the trick:
http://articles.techrepublic.com.com/5100-10878_11-6031733.html
It says to use a floppy, but you can also put those files on a USB drive and boot from that.
Posted on Jul 27, 2008
Hp compaq 530usdt windows\system32\conf\system. File missing or corrupt
insert original win installation cd and reboot... when in boot mode make sure you are booting from CD, not from disk, when message asking that you "boot up from cd " appears, just press any key, and folow procedure, but do not install a new copy of windows ! There must be "repair your computer" option on your CD, for Win Xp - it is "recovery console" ! When repairing finishes restart computer and boot from disk (just do not press anything when you see message "boot from CD..." and let windows from HDD configure it self).
Mar 10, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Cause
  1. Keyboard issue
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
OS Loader v4.01
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Error: windows root>\system32\ntoskrnl.exe
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
ACER DESKTOP COMPUTER
Related errors:
Cause:
  1. Keyboard issue
best regards wish u give me a good rate ^^
Aug 15, 2008 | Acer Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
