Question about Sony (B99860307) for VAIO PCG-K series Motherboard
Booting problems. When i boot my Sony PCG-K74 VAIO computer it starts up with the display far too large for the screen. Occasionally it will start correctly. can you help with any suggestions? This problem is driving us crazy
  • 1 more comment
  • grjecaab Jul 27, 2008
    No it does the same thing in safe mode. I thought it may be a video card driver problem. but I am not an expert.
  • Shaun Harris
    Shaun Harris May 11, 2010
    Are you using an onboard video or do you have a video card installed?
  • John Byse
    John Byse May 11, 2010
    Is it starting in "Safe Mode"? In the four corners you will see "Safe Mode". MM85
  • 781 Answers
Try right click desktop go to properties/display setting check that display is set properly go to advanced settings check out there if everything OK go to control panel/device drivers uninstall video drivers reboot it should boot with standard vga drivers check if display is OK then try loading your proper video drivers
Posted on Jul 27, 2008
How do I factory reset a Sony Vaio PCG-792L aptop with Ubuntu?
Download the version of Ubuntu you require, burn it to a disc. Start the Sony up, booting from the DVD drive and install a fresh OS.
Dec 29, 2015 | Sony Computers & Internet
Hello, I am contacting you on behalf of my cousin whose computer crashed. She has a system restore disk and I instructed her to reset the order of start up in the BIOS by moving the CD/DVD drive to the...
One of the function keys should get you into the boot menu, F9-F12, to manually select the CD/DVD drive. Pressing Esc or Tab on VAIO logo may display the right information to show which key to press.
Have you tried booting a standard Windows setup disc and checked if the hard disk is working ok?
Aug 24, 2011 | Sony VAIO PCG-K33P Notebook
Vaio can be a fussy devil to boot the way you want it too...
Typically when you see reference to a partition not being detected, it means that the hard disk drive is failing to register in the laptop, or has been damaged.
I am going to assume that the laptop is not detecting the CD and able to boot from it, even though it is set too...
Have her try looking in the BIOS again to see if it can be set to "Check for boot disk".
Most systems also have a key that can be pressed to provide a boot menu, prior to booting automatically.
With the Vaio, it is the "ESC" key. If this key is pressed, just after seeing the Vaio screen, you should be able to force it to boot from CD/DVD.
I have a sony pcg z505rx which I cannot remember windows password. Therefore, I downloaded ubuntu to a usb memory stick and am trying to install in my computer. I have entered the bios screen but am unable...
IF YOU HAVE FORGOTTEN WINDOWS PASSWORD THERE IS A BETTER WAY TO LOGIN TO WINDOWS. WHEN YOU START THE COMPUTER EVEN BEFORE WINDOWS STARTS BOOTING KEEP PRESSING F8 AGAIN AND AGAIN. HERE YOU WILL GET A MENU. IN THAT SELECT SAFE MODE AND ENTER. NOW WINDOWS WILL BOOT IN SAFE MODE. HERE YOU CAN CHANGE YOUR ACCOUNT DETAILS OR CREAT NEW ACCOUNTS .
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Sony Vaio PCG Z505 series Laptop Universal...
I have a Sony Vaio PCG-8A8M with display problems.
sounds like the display/monitor is about to go... backup your files...externally
Sep 13, 2009 | Computers & Internet
When i start up my computer the screen blinks like it has a bad connection then it goes black
the connection may have come loose or screen damaged, try booting in safe mode. if screen still does nothing you will have to check the above,
if screen works, the display settings may be too high.
Jan 27, 2009 | Sony VAIO PCG-GRT360ZG Notebook
Notebook will not fully startup
You will have to F8 during boot up and run a system restore I am assuming you are running vista...in the F8 boot screen there is a repair vista.. or something along those lines... The problem is a bad update that needs to be re done most likely Sp1
Jan 23, 2009 | Sony VAIO PCG-K23 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Dec 18, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
157 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
