Question about RCA Televison & Video
Need steps to program remote - RCA Televison & Video
  • 163 Answers
I need make and Model of remote......
Posted on Jul 27, 2008
Programming key fobs for a 2007 Silverado
If Your 2007-2010 Silverado Has a VIC - Vehicle Information Center Step 1: Sit in the vehicle with all the doors closed and unlocked. Start your Silverado and leave it in Park.
Step 2: Press and hold the Vehicle Information button, marked by an image of a car and the letter "i", until the display reads "Press V to Relearn Remote Key".
Step 3: Press the Set/Reset button until "Remote Key Learning Active" appears.
Step 4: Simultaneously press and hold the Lock and Unlock buttons for 15 seconds. A chime will sound indicating the remote has been successfully programmed.
Step 5: Program additional remotes by repeating Step 4 for each fob.
Step 6: Exit programming mode by turning off the vehicle and removing the key.
Step 7: Test your remote(s).
If Your 2007-2010 Silverado Doesn't Have a VIC - Vehicle Information System Step 1: Sit in the vehicle with all the doors closed and unlocked. Turn the key to Accessory Power position.
Step 2: Press the trip odometer meter reset stem repeatedly until you see "Relearn Remote Key".
Step 3: Press and hold the trip odometer meter stem for three seconds. The display will read "Key Learning Active".
Nov 02, 2016 | Chevrolet Silverado Cars & Trucks
Need to program remote back to RCA HDTV Model# D52W19
download the manual for steps by steps from www. fitness.manualsonline.com or www. retrevo.com and fix it
God bless you
Jul 03, 2013 | RCA RCR311TFM1 Remote Control 261669
How do set the lock remote for a 2001 Honda civic
Try this:
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Mar 12, 2013 | Cars & Trucks
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
Programming a remote
Sep 01, 2009 | Televison & Video
1999 civic key fob reprogramming
Oct 25, 2008 | Honda Vehicle Parts & Accessories
Program my remot
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
remote programming instrutions start on page 49 of the PDF file and give step by step instructions for programming your remote
Feb 26, 2008 | Hughes HRMC11 Remote Control
Lost code and instruction book?
Orion Codes: 035, 121, 135, 191, 394 Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.pdf Hope this helps, Good Luck :) Please Vote
Jul 10, 2007 | GE RM24911 Remote Control
Lost the manual. Can't re-program remote control. Need step-by-step
http://www.rca.com/documents/15128800_201059_25.pdf Hope this helps :)
Apr 08, 2007 | Proscan PS35660 TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
