Question about Electrical Supplies
Brass Champion Sprinkler Valve
Sprinkler valve leaking...lowest sprinkler head leaks when off. Cannot find a photo to show breakdown of champion valve to repair it.
    Problem Solver:
  • 5 Answers
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Posted on Jul 27, 2008
Why is replacement sprinkler head leaking?
If water pressure is over minimum recommended rate, your replacement sprinkler head shouldn't leak; it it's leaking probably because it is of a very bad quality. If it's new, return it to the shop where you bought it and clim your warranty right
Sep 13, 2015 | Garden
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
What causes a sprinkler to leak after shot-off ?
It could be the shutoff valve (debris in stem tip), but most likely cause is that the sprinkler is the lowest point in that line and, after shutoff, the water in the system is draining to the lowest point.
Aug 23, 2014 | CHAMPION IRRIGATION PD Dv-050 Valve Drain...
Can this valve be repaired?
Check to see if the company has a rebuild kit for the unit.
Jun 06, 2014 | Orbit 51016 3/4" Brass Anti-Siphon Valve
Indexing valve leaking water
Sounds like the anti-siphon cap, unscrew and check the gasket. If it is the other side tighten the screws if sill leaks valve body could be cracked and needs to be replaced.
Mar 24, 2014 | Fimco 1 in. 10 psi 4 Outlet Indexing Valve...
Irrigation valve parts diagram
Most likely cause is small bit of contaminant (TFE tape, etc.) is caught in the seat area, or possibly (if electrically actuated) the solenoid is not working properly.
Jul 24, 2013 | CHAMPION IRRIGATION PD Champion Irrigation...
No i don't just trying to help a elderly lady
It's not the sprinkler. The valve is not seating completely. You will notice the sprinkler it is leaking from is the lowest one in that particular zone. Don't take it out on the sprinkler it's not his fault. Think of it as if you didn't shut a hose bib off completely the leak doesn't drip at the bib it shows up at the end of the garden hose. Same principal. The valve is the hose bib.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
Instructions for champion valve actuator PCL-075-B
You have this posted in the wrong category, please re-post.
Jun 01, 2012 | Cars & Trucks
Our raintrain has worked for years....but now it is leaking out of the bottom causing it to get stuck often......please help us!!!!
I think your valve is shot. There is a button underneath that is pushed up by the ramp. It then closes the valve. The valve is leaking and lowering your water pressure causing your sprinkler to get stuck.
You could replace the valve but that requires disassembly of the gear box. The gears inside may be worn too so, I am suggesting that you just replace the gear box. Replacing the gear box will give you all new moving (and sealing) parts. This web site has a box for about 1/2 to 1/4 the price of a new sprinkler.
http://www.sprinklersupplies4less.com/traveling-sprinklers-nelson-1865-replacement-parts-c-384_627.html
Jul 08, 2011 | Nelson Sprinkler: Traveling Tractor
The timer no longer plays all 3 programmed zones. It play only one.
Three things to look for:
1) If sprinkler turns on-off but doesn't advance to next zone, then Sprinkler Valve is suspect, and timer is good.
2) If sprinkler stays on all the time, or never turns on, then Timer is suspect.
3) If sprinkler turns on-off, but leaks when it's supposed to be off, then Sprinkler Valve is suspect, and timer is good.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jun 24, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
Electrical Supplies Logo
2,702 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
