Question about Panasonic Televison & Video
S-video How do I use the s-vid I have it hooked up but can't seem to access it in my menu. Do I still have to use the rca jacks?
  • 163 Answers
S-Video is just that, video.. It is usually used in tandem with the RCA audio inputs of line 1, line 2, etc. S-video has slightly highder quality than the standard line level (RCA yellow) video. MM85
Posted on Jul 27, 2008
How to plug protron 20 lt20c1e1 into hp pavilion laptop
plug protron 20 LT20c1e1 as i ask my kid long ago, animal mineral vegetable.
answer, mineral.
or partly veg. with fossil fuel plastics sure.
ahhhhh google said its an LCD TV. TEEVEE or TELLY
so what are the jacks there?, I cant see em.
seem you lost your manual that it?
no Pavilion model stated. my guesS VGA jack there 19pin D-shell.?
in what country, TV not same world wide, a fact.
omg obscure TV it is.....
20" TV is super old and tiny.
looking a 26" manual
there is no HDMI
no VGA
shows connecting to PC with adapter types.
1: COMPOSITE VIDEO RCA TO vga ADAPATER
2: sVIDEO JACK TO vga ADAPTER. WORSE QUALITY
SVIDEO IS 4 PIN ROUND DIN JACK.
#1 IS BEST
there is 3 RCA jack video, and 1 audio COmponent jacks.
and 2 cable (composite ) one is vid other is sound.
sound is 3.5mm phone jack.
i cant see the side of your tv
nor see what the words are on each jack
and the manual is ,impossible to find.
Jan 07, 2018 | HP Computers & Internet
Sa8100x technics
The Tape out jacks on the back of the receiver function as RCA audio jacks, On this receiver I own the same one there beauts :-)
Aug 05, 2013 | Panasonic Vintage Technics Cd4 Stereo Am...
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
My S Video from laptop works with TV however no sound on TV
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
Aug 28, 2009 | HP Pavilion Elite M9150F Desktop PC
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Home theater sound
Most plasmas have set of RCA jacks beside or near each video input, be it a yellow composite jack, component (RGB) or VGA (15 pin monitor cable) there should be a red &white set of jacks beside each input. There should be a r&w set marked audio out.thats what you want goin' to the Hi-Fi a/v input. All this is on the assumption that the plasma has no speakers of it's own. if it does, you may need to go to set up menu and check audiosettings on the tv.Your best bet is to go HDVI between the DVD/Sound if you have the ability on both units. Better vid and audio that way.
Dec 29, 2007 | Audio Players & Recorders
No video output from rca jack or svideo
The problem is with the p.scan button. It seems if its pressed the video goes off. You need to keep it pushed until you see a message for "progressive scan".
Dec 08, 2007 | Samsung DVDR120 DVD Recorder
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
