Question about GE JVM1440 Microwave Oven
Magnetron tube i received the magnetron tube from ge..need schematics to replace it..not on their website
  • GE Master
  • 9,098 Answers
Short of buying the service manual, you can find helpful exploded view diagrams by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Replacing the magnetron will require the removal of a lot of screws. Keep track of where they all go.
We have critical safety information at our site, and our link is at our listing here on FixYa.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
My GE model JVM1631WB002 is giving off a burning smell. What can I do?
A burning smell is usually a sign of a bad magnetron tube, the microwave source. As they age they take more power, and this causes excess heating that can cause the smell. Eventually the tube burns out and you get no heating. If you've been noticing longer than normal cooking times, it's due to the weak tube.
You can replace a magnetron, but it's a costly part (around $100-$125) and the repair should be done by a professional because of safety concerns. (Several websites describe how to replace a magnetron if you'd like to try it yourself, but you need to be very careful. MICROWAVES USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU.) Between the part and labor costs, when the magnetron goes bad it's often more economical to spend a little more and replace the oven.
There are some other parts that can get hot and sometimes smell, but the magnetron is most common. If you want to keep the oven, I'd suggest letting a professional check it over and give you an estimated for the repair. Then you can decide what you want to do.
Jun 06, 2011 | GE JVM1631 Microwave Oven
Won't heat any foods.
you have a problem with your magnetron tube, and when the magnetron tube goes bad, the diode almost always goes out with it. you should be able to order a replacement tube from your manufacturers website, if you cant let me know and ill try to help you more.
here are the steps to replace the magnetron tube, if you want to do it yourself that is. if you have a professional do it, it can be pretty costly.
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Dec 07, 2010 | Whirlpool MH7140XF Microwave Oven
Evry thing works except the food is not heated. It makes the noise, timer counts down..
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side of the blower housing, or magnetron tube assembly)))
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
(((The fuse is located inside the unit along side the magnetron)))
Sep 10, 2009 | GE JVM1630 Microwave Oven
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace the magnetron tube
Remove the connectors and unscrew the mounting screws pull out the defective unit and put a new one.
May 16, 2009 | GE JVM1631 Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Tami,
It isn't really difficult to replace... It's the 4000 Volts that go to it and the stored energy (voltage) in the high voltage capacitor that concerns me as far as telling you that it is a do it yourself repair. Also, and this a huge concern, is that after the magnetron tube is replaced, the microwave should be leak checked. A microwave leak detector that is certified is around $400. Now that I said that, I have rarely ever had one that leaked, but it is the law and that's the main reason that it needs to be done. I highly recommend calling GE Factory Service 1-800-432-2737 (1-800-GE Cares) to install the magnetron tube.
Brian
Jan 15, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
Need install schematics for magnetron tube for ge jvm1440ba
You can download GE owner's manuals and installation instructions here.
Jul 27, 2008 | GE JVM1440 Microwave Oven
GE JVM1440 Microwave Oven Logo
421 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
