Question about Kenmore 66312/66319 Microwave Oven
Microwave will not turn off
The timer has expired; however the turntable still turns and the power is still functioning. Once the door is opened, the power stops,,,after the microwave door closes, the turntable turns, and the microwave functions.
  • Anonymous Mar 24, 2014
    I have a Russell
    Hobb microwave when I switch it on at the mains the turntable turns and the light is on and only stops when I open the door I can't seem to stop it turning unless I open the door or turn it off at the mains ?
  • Kenmore Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
My microwave has stopped working. Everything functions properly, including the light when the door is open, and the timer countdown begins when I press start, but the actual unit will not turn on...
Sounds like a bad magnatron (the part that emits microwave energy) or maybe just a bad door switch. If the door switch is bad it won't let the unit come on.
Feb 19, 2015 | In Microwave Ovens
Microwave turntable keeps turning even after timer is off and door is open
There are one or two door switches that have become defective, they must be replaced for normal operation.
Mar 24, 2012 | GE Microwave Ovens
I have a model number EM925RSL-B and the timer counts down but it does not heat up or turntable does not move?
I just bought an RV with the exact same microwave and the exact same problem. The problem with mine is the switch that detects that the door is closed is not getting activated. The reason for this is is the finger at the top of the door is damaged as well as the plastic piece that the finger grabs onto when the door is closed. This causes the finger not to come into contact with the switch. To test this you can turn your microwave on and start it. open the door and using a small screwdriver, depress the micro switch you can see upper right side of the door opening. then press start again. your turntable will start turning and the microwave will make a louder noise as a fan will turn on. CAUTION! Release the button as soon as you see the turntable rotation as you will be receiving microwave energy due to the door being opened.
Jul 02, 2011 | Microwave Ovens
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
I have a Whirlpool AMW545 built in microwave oven. The turntable continuosly runs with the door shut when the microwave is not in use. The turntable will stop rotating if the door is opened.
the controller for the turntable is shorted out or welded its contact if its a relay. the door has safety switches that turns off the electrical connection to the turntable and magnetron once you open the door. you can trace the switch that runs the turntable. start from the power supply, goes to the door switch then to the controller before it goes to the turntable motor. i'm sure it has an electrical diagram at the inner wall of the cover.
i hope i was able to help.
Jun 27, 2008 | Whirlpool Microwave Ovens
If we close the mircowave door the units start to run by itself. - it will not heat, but the light comes on and the turntable rotates it will not stop until we turn the power off - when power is turned...
i think you have a welded controller, either a digital one or a mechanical one. microwave won't run unless you switch it to run. the door switches are safety switches to turn off the microwave once you open the door. if you have a digital controller, you could have a welded relay, if you have a mechanical timer, it could be a welded contact at the timer. another thing is that it should heat what ever you are heating. if it is not heating, check if it has a fuse and if it is busted. some fuse are installed to protect only the magnetron that is why the light and turn table are still running. if there is no fuse to the magnetron, then check the diode from the capacitor to the ground. it could be open. if not then you can have a bad magnetron. i hope i was able to help.
Jun 24, 2008 | LG Microwave Ovens
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 66312/66319 Microwave Oven Logo
5,208 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
