Home | Toshiba | DP5570 Laser Printer | Printer Properties cra...
Toshiba DP5570 Laser Printer
Problem for Toshiba DP5570 Laser Printer
Printer Properties crashes explorer
By Brad - usenet poster
I just purchased a new computer (Dell) with W2K installed. I added a Toshiba
DP5570 printer and when I try to access the Properties page the screen goes
blank except for the blue background (not the BSOD blue) and the taskbar and
desktop icons reappear. All explorer windows are closed but other apps are
not. I can access "Printing properties..." but not the "Properties..." page.
I subsequently installed an HP4Si and Adobe Acrobat and I can not get to
thos properties pages either. Also, uninstalling the Toshiba does not help.
The really wierd thing is that I get no error message what so ever.
I can easily start from scratch but any ideas about resolving this problem
are appreciated.
Chris VanRemoortel
Same Problem
Dec 05, 2007
-   yes-   Guest
Solution #1
posted on Aug 11, 2005
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
First, you need to answer a  of question.
Do you have Novel Client 4.7x installed?  If you do, try removing the NPDS
service.  You should see it under the Local Area Connection Properties.  If this
solves your problem, then install a newer version of Novel.  The version you
were using had a bug in it.
Was this helpful?
Yes
No
Solution #2
Not Rated)
herself
Rank: Apprentice
Rating: 0%, 0 votes
Yes, I do. I have disabled NDPS and everything works. I am download the new
client as I write this. Thanks!
Was this helpful?
Yes
No
Popular Solutions for Toshiba DP5570 Laser Printer
Questions and Unsolved Problems for Toshiba DP5570 Laser Printer
Do you recommend Toshiba DP5570 Laser Printer?
Answer
Answer
how do you change a C4706-60082 HP DesignJet Plotter Carraige belt (E-size), 36 inch. This is an HP... (More)
Answer
I don't know how to scan a photo
Answer
A sign ''remove paper form dulexer'' pops up and won't allow me to make double sided copies.
Answer
I am trying to print on legal paper and it will not let me. Please help
Answer
our papaer jammed then we got a prompt saying set developer unit
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba DP5570 Laser Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
