I want to change my set up from the original to windows xp version. Can i do this?
I have problem with my desktop that no icons visible on my desktop screen and also the start menu is not visible.How can i make visible them.
Posted on Jul 27, 2008
Toshiba laptop serial NO 76110651Q
Check the bottom of the laptop for a Certificate of Authentication (COA) sticker which will tell what version of Windows XP it had and the Key Code (a series of 5 letters and numbers). If you have a copy of windows xp that is the exact same version as on the COA then you can install it and put in your keycode when requested and activate it. If your COA says Windows XP Professional you cannot use a Windows XP Home operating disk to reinstall.
Apr 26, 2012 | Toshiba Computers & Internet
Tip
Make older programs run in Windows XP.
If you're having trouble running older programs originally developed for previous versions of Windows, you're not out of luck. Luckily for consumers, Microsoft built Compatibility Mode into XP. Compatibility Mode allows you to run a program using the shell of the original program it was developed for. Today Chris shows you how to access a program's Compatibility Mode in XP:
  1. Find the executable or program shortcut icon you'd like to run.
  2. Right-click the icon and select Properties.
  3. Click the Compatibility tab and place a checkmark next to the text labeled "Run this program in compatibility mode."
  4. Select the operating system that the program was originally intended to run on.
  5. You may need to fine-tune the three fields under "Display Settings" if an older program requires 640x480 resolution or 256 colors.
  6. Click Apply.
Try starting the program after making these changes. If it still gives you trouble, try a different operating system. If the program was written for Win95 and worked fine in Win98, there's nothing that says it still won't work fine with Win98.
on Jun 03, 2008 | Microsoft Windows XP Professional
Why can't I download my CANO SCAN set up CD-Rom on to my new Windows 7
The CD-ROM has the installers for older versions of Windows. The installation routines for the newer versions of Windows have changed considerably from those that were in use when the CD was written. You can get the drivers and Canon Toolbox software for the scanner from Canon: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware . Select Windows 7 in the dropdown menu. The software will work with any version of Windows 7.
The only exception is that the third-party software is not available for downloads. If you want to use the original CD software (assuming the disc is undamaged) and you have Windows 7 Pro or Ultimate, you can download and install Virtual PC and XP mode for a free XP virtual computer. Then install the scanner to the "XP computer" as you normally would. However, the virtual computer and the Win7 computer cannot both have the hardware installed simultaneously. So to share files, you may need to save them to external media (optical or hard drive). If you have one of the other versions of Windows 7, you can do the same thing with any virtual PC program and a licensed older version of Windows.
I hope this helps.
Feb 12, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
My windows xp is not original. Can I download it for free? If so, should I remove the current one first? tks
u can get only the pirated versions or trial versions of windows from the net. if u want original copy u have to buy it.
Apr 07, 2010 | Microsoft Windows XP Home Edition
I have windows xp laptop that was given to me from a friend its in japanese i have no idea how to change it to english version please help me? Vicky
Hi Vicky, how are you?
Here's the story with Windows XP... On a system running ENGLISH Windows XP (Professional ONLY), you can put a Multi-language User Interface (MUI in short) and make it localized. This action is reversible, means you can go back to English at any time or switch to another language. BUT, if the original Windows language is NOT English, you just can't switch the user interface to English.
How to check if it's original English version or not? - Go to Control Panel (a symbol of a notebook and a pen) -> Regional and Language Options (a symbol of a globe). Click on the Languages tab (the middle one). If there's a selection box at the button - you're in luck! Click it and change to English. Then accept and restart!
In there's no selection box - I'm sorry but you'll have to format and install an English version of Windows XP - Home or Professional - whatever fits you best!
Hope I helped,
Pelu.
PS: On laptops that ships with Windows pre-installed in a localized version (language), there's SOMETIMES an indicator to it on the license sticker at the bottom of the laptop.
Mar 16, 2010 | HP Compaq Presario C500t Notebook
How to Change Windows Language From Arabic to English?
There is no way of changing the language in XP, on some version of vista you can do it true the Windows update utility by downloading your language pack.
But in XP you have to reinstall.
Sorry
Jun 01, 2009 | ASUS Eee 4G Notebook
Din't do any changes only when trouble shooting all original equipment.The restore cd dont ask for key but the xp cd does. Same problem.
I asked, because many do not know that you cannot install a lesser
version, nor a version of the same build, or a better build, unless you
boot from CDROM.
The Restore disk isn't going to restore, unless the original hardware
components are inside, right? Windows sets 'codecs' for all of the major
hardware components. If you change two or more, Windows wants you
to activate again.
Windows 98 didn't care, because this was a fresh
install, and you provided the product key.
The full installation disk of Windows does care, because this is a fresh install, and the product key doesn't match the codecs, set for the
hardware inside. So just type the product key in, and away you go.
Or have I missed where you entered the key, and it still doesn't work?
I await your comment.
May 17, 2009 | E-Machines eMachines Desktop PC
Hello. Simply need XP drivers for e-machine model W4682 so XP can be reloaded from scratch. Vendor site is useless. Any info would be helpful.
here you go this should be all your drivers.
Modem Description Riesling Modem Driver File Type Original Driver Version 7.4.5.50 Operating System Windows XP Driver File Download (1.44 MB)
Chipset Description Intel Chipset Driver File Type Original Driver Version 5.0.2.1003 Operating System Windows XP Driver File Download (2.65 MB)
Video Description Intel 845GV Video Driver File Type Original Driver Version 6.14.10.3722 Operating System Windows XP Driver File Download (7.15 MB)
Media Reader Description Universal 8-in-2 Media Reader Software File Type Original Driver Version 1.08 Operating System Windows XP Driver File Download (4.40 MB)
Audio Description Realtek AC'97 Audio Driver File Type Original Driver Version 5.10.0.5320 Operating System Windows XP Driver File Download (16.70 MB)
Network Description RealTek Onboard LAN Driver File Type Original Driver Version 5.606.811.2003 Operating System Windows XP Read Me File Download Driver File Download (2.20 MB)
hope this helps if this isnt the correct series its the w-468 series drivers
Jun 18, 2008 | E-Machines Computers & Internet
Screen problems
you buy a copy of original windows xp online from microsoft site www.microsoft.com. for the screen check to sure that the signal cable is well fix to the power module and be sure that the power module is okay.
May 28, 2008 | Acer Aspire 5610 Notebook
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
