Question about Samsung S7350 Ultra SLIDE Cell Phone
How to connect the phone to pc laptop? - Samsung S7350 Ultra SLIDE Cell Phone
  • 812 Answers
Hello thanks for using fixya
To connect the Samsung Set with PC or Laptop u need PC Studio of Samsung.You need to download PC Studio then install it, then you can easily connect your samsung set with your PC
After clicking downloading will automatically start. Download it
After downloading to know How to install it download the given guide. Follow the steps given in guide step by step
To download Guide Click Here
Guide is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Posted on Feb 21, 2011
SOURCE:
How to connect phone line to toshiba laptop A665 computer
Hi
If you have a modem builit into your laptop there will be a port on the side to connect the phone cable to, then plug the other end into your phone socket and you should have a connection to phone line
Cliff Cook
MCP
Jul 30, 2014 | Toshiba Satellite A665-S6086 Laptop
Usb connection settings
No setting required. Install Nokia pc suite in your pc/laptop and Just connect your phone using usb cable to pc or laptop and wait 5-10 minutes it will install all required setting automatically. Then u can see your phone connected in PC Suite application.
Jan 28, 2014 | Nokia 5230 Cell Phone
Hi, I have a samsung c5220. how do I install the software to my mini laptop so I can tether. issue is my mini laptop doesn't have a cd rom. Appreciate your help. Thank you
Hi
Try downloading your phone's PC Suite on your laptop from the link below.Use the phone's USB data cable for connections.Choose PC connection on your phone as the connection type.
www.brothersoft.com/samsung-pc-studio-78015.html
Hope it helps.Thanks!
Mar 03, 2012 | Samsung Cell Phones
I have a Nokia 6700. How do I download a PC Suite for this phone?
Possible there are errors in the PC and so the phone is not recognised. You can transfer the pictures by removing the micro sd card and inserting on a card adapter to be directly read on the card reader on the laptop. If this is not possible you can activate bluetooth on the phone and laptop and get the files transferred easily after detection.
finally remove any programs particularly if a phone was installed earlier and reinstall the Phone.
Get tips from the link below:
http://cellular.wirenode.m/obi.
h
ttp://www.nokia.co.id/dukungan/software/nokia-pc-suites/compatibility-and-download#
Dec 05, 2011 | Nokia 6700 Slide Cell Phone
I am using samsung GT-S 5233a i got a pc studio disc with the phone. My laptop is windows 7 ultimate and i cant install pc studio to my laptop. because of that i cant connect to my phone with my laptop...
Perhapse this worked (without New pc studio, But install samsung Drivers from CD).
Solution: In your cellphone go to Settings---> Phone settings---> PC connections and select Media player option (or Ask on connection). Connect your cable (if you select Ask on connection option, you should response to your cellphone and select Media player option )and when the cellphone connected, open the My computer. Perhapse you can see your cellphone there.
Jul 05, 2011 | Samsung Star GT-S5233 Cell Phone
Can not connect my mobile phone to my laptop
You have to enable the feature USB mode: Mass Storage on most phones to get a connection that is similar to a flash drive.
If your phone's operating system is Windows Mobile 6.1,6.5.x or Windows Phone 7 you need a software called Mobile Device Center to make an Active Sync connection.
If your phone is an Android powered one, you should use Android SDK to connect it to your PC.
Mar 20, 2011 | Computers & Internet
How to use the Nokia PC suite with the HCL Laptop computer
dear connect ur phone with pc suit then make dailup internet connection.control pannl -> network connections-> new connection
Jan 23, 2010 | Nokia 3110 Cellular Phone
Nokia 6070 internet connection
www.blogfortech.co.cc
go to this link u will find the PC suite for Serial cable
Download that and install on your PC/laptop
Connect ypor mobile to PC/laptop via CA-42 cable
When youR phone gets connected to your PC/laptop
go to control panel and then in phone and modems and
go to modems and select add new and click on 'dont insatall my modem i will select from the list'
after that select manufacture nokia and select modem of NOKIA 3200 and select the port ON WHICH YOUR PHONE IS CONNECTED
dont select the different port you will not be connected to internet.
and finish it
NOTE:-Install your modem only when your phone is connected.
Go to PC suite and click on the modem you installed
and provide your Operator setting and you have done it.
NOTE:-when your connection is Established your Phone will be disconnected from the PC suite
After disconnecting from the internet Your phone will again connected to PC suite.
ENJOY...........
Jan 08, 2009 | Cell Phones
Samsung D900i- how to get phots onto my laptop
dear sir
u have a drvier cd with phone give u when u perchase that phone and when u connect your phone to pc it's show SamsungD900i found then u give path from yr drvier cd it's depend whitch OS u company give all most OS drvier built in CD u have to install software first which also located in CD then connect yr phone to pc as my sujjaction first install full softwre and drvier after connect yr phone to yr Pc and if u allready connect yr phone just plug out then install software and drviers after finesh installaction restart pc then connect yr Phone to OTHER USB prort. it's help u..:)
Thanks
Please vote
jo_Chinmay
Dec 23, 2008 | Samsung SGH-D900 Cellular Phone
Samsung S7350 Ultra SLIDE Cell Phone Logo
127 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
