Sanyo EM-Z2100GS 900 Watts Microwave Oven
Problem for Sanyo EM-Z2100GS 900 Watts Microwave Oven
I think fuse is gone????? Any help???????
By panzer88 on Jul 27, 2008
How do i get to the fuse in the
EM-Z2100GS this is the second one i have gotten and @ first didnt know what was wrong so i threw it out and got a new one. And the same thing happened just stopped working and i think its the fuse but how do i get to it??
Best Solution
posted on Aug 02, 2008
Very Helpful)
MicrowaveSvc
Rank: Guru  Sanyo Kitchen Appliances  Expert
Rating: 89%, 5354 votes
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Many Emerson microwave manuals are available for free download here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sanyo EM-Z2100GS 900 Watts
Questions and Unsolved Problems for Sanyo EM-Z2100GS 900 Watts
Do you recommend Sanyo EM-Z2100GS 900 Watts Microwave Oven?
Answer
Answer
my sanyo 800 watt compact microwave is running but is not cooking or heating. What could the problem... (More)
Answer
we have a Sanyo EM-SL30N, and unfortunately i dropped the glass turntable and it broke. Where can we... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
in , PA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
