* ALWAYS UNPLUG YOUR AMPLIFIER BEFORE REMOVING TUBES *
If you can see that a tube is definitely not lighting up then it may be blown. If this amp has seen regular use then it may be time for a new set of tubes. Try replacing the 12AX7s first before committing to a new set of 6L6s. Though, if you have the cash available, a new set of power tubes isn't a bad idea either. I would advise you to do the preamp tubes first and play through the amp for a few days first before changing the power tubes.
Keep in mind... if a tube (or tubes) has blown, there could be another issue in the circuit. Swapping in a new tubes is a quick way to determine that. Then it would be time to take it to your local repair shop.
Good luck and keep rockin'!
