Question about Hannspree Disney Pooh Smile 9.6" TV
I Have A disney tv model # DT1350-RWP
When i turn on my tv it won't stay on, it turns off right away.
Sound won't work on my Disney dvd/tv combo
Either the speaker is bad or broken wire OR more likely the headphone jack is the issue---when jack comes out it lets a leaf in the socket engage the speaker back----when used a lot the jack causes no sound.
Nov 02, 2012 | Disney DT1350-C 13" TV
Disney tv model # dt1350-c looking for speakers to this tv.
It can be bought from electronic spare part selling shops. Go with the damaged speaker. Let it be in hand as sample. It won't cost more.
May 11, 2012 | Disney Lightning McQueen TV
Disney princess tv shut off and won't turn back on. is there a rest on it.
Sorry, there is not a reset on this TV.
No signs of life can be anything from a Fuse, to failed components on the power supply.
I suggest having it to a local repair shop which has the training and proper equipment to disassemble the TV and replace the failed component(s).
Expect a diagnostic fee of $40 (depending on your location) that is credited toward the repair bill.
Thanks
Nov 02, 2011 | Disney DT1350-P 13" TV
My child had her remot to her disney tv ad thevolume went out. I want to know wats wrong with tv. I tried everything and volume won't comeback on.
Check if you mistakenly hot the mute button. If not check other remotes, i.e cable, set top box remote volume. Thumb me up if I helped. :)
Jul 02, 2011 | Disney DT1350-P 13" TV
Need a remote fr disney tv
Replacement remotes for this model can be found here:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DT1350-P&uuid=12955839194070
Jan 21, 2011 | Disney DT1350-P 13" TV
Need a remote for p3815nt
Hello
Disney is listed in Philips Universal Remote Control Model ( CL 034 ). There is only one code specified for Disney TV and it is
0417
The proceedings are:-
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Ok.
Nov 29, 2010 | Disney DT1350-P 13" TV
How do I get the TV in video mode
There should be an "input" or "source" button on the remote. If you press this a couple of times, you should eventually get to the video mode, if not right away. I hope this helps! Der Strom
Apr 13, 2010 | Disney DT1350-C 13" TV
How to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Nov 12, 2007 | Disney DT1350-P 13" TV
Hannspree Disney Pooh Smile 9.6" TV Logo
174 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
