Question about Ecoquest Breeze AT Living Air Purifier
PROBLEM WITH BREEZE AT
OPERATES APPROPRIATELY FOR APROX. 20 MINUTES, SHUTS SELF OFF. RESTARTS OKAY RUNS 20 MINUTES OKAY IN CYCLES
  • 80 Answers
It sounds like the fan motor may need to be oiled, front and rear. That has been my experience with stopping and starting at that length of interval.
Posted on Apr 04, 2009
Id like some instruction on how to use ? curently trying to remove odours from a vehicle ? some instructions on how to use the unit would be a great help
Odors from a vehicle takes 2-14 hours on "high". Depends on the odors. Run the AC & heater fan for 20 minutes also when the car is full of ozone and have the unit aimed up on the floor toward the firewall on high. You should not stay in the car while doing this. Mild new odors can be neutralized in 20 minutes to 2 hours. Bigger and older problems take longer.
May 23, 2011 | Ecoquest Breeze AT Living Air Purifier
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
Turns on but only runs for a minute or two and then shuts off
needs to clean up and lubricate wit 3in1 oil on the center of the fan . and be careful no to drip oil on oters components
Mar 31, 2010 | Ecoquest Breeze AT Living Air Purifier
How do I clean my EcoQuest Breeze?
The purifier should be cleaned about once a month and you should do the following:
  1. Unplug the Breeze before cleaning.
  2. Wipe the Breeze with a soft cloth dampened with water, vacuum the front grill to remove any lint buildup.
  3. Cleaning the rear lint screen - You can either vacuum the filter or you can wash in hot water. Allow to dry before reinstalling the lint screen. Do not use soap, it will damage the carbon material in the lint screen.
  4. Remove the purifier plate from the purifier and soak in 1 part amonia and 1 part water solution for 10-20 minutes. Gently scrub the metal grid on the plate with a toothbrush and rinse with water. Clean the metal contacts with the same solution. Allow the plate to dry overnight or use a hair dryer to dry throughly.
Dec 07, 2009 | Ecoquest Breeze AT Living Air Purifier
The unit continually shuts on and off with slight sparking sound.
sharper image had a class action lawsuit against them for the ionic breeze units, you should look into it
Dec 03, 2009 | Sharper Image Ionic Breeze 3.0 Air...
How do you reset a Quadra ,Ionic Breeze
Hi.
This appliance simply resets by disconnecting the power cord for five minutes. The control board does not include battery.
If the model was manufactured before 2007, pleas read below.
Ionic Breeze Concerns
Regards.
Ginko.
Nov 14, 2009 | Sharper Image Professional Plus Ionic...
My Apline Living Air does not create any ozone. The fan runs but the green light only turned on once.
Are the plates cleaned? They should be cleaned once a month by soaking in 1 part amonia and 1 part water for 10 minutes. Scrub with a toothbrush and rinse throughly with water. Allow the plate to dry overnight or use a hair dryer to dry throughly. Hope this helps.
Oct 12, 2009 | Ecoquest Breeze AT Living Air Purifier
Ionic Breeze Red cleaning light on after a few minutes of running
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
There's a link to the manual here:
http://www.amazon.com/Sharper-Image-Breeze%C2%AE-Purifier-SI637BLK/dp/B0000AUTU3
Oct 04, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ecoquest Breeze AT Living Air Purifier Logo
133 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
