Question about Olympus FE-110 Digital Camera
Camera will not power on
With new batterys camera flashes both red and green lights when trying to power up than stops after 3 seconds.
before things were working fine transfering pictures to my laptop but then while viewing pics I did'nt disconnect camera, thats when it started too beep and lights flash.
I suspect camera has froze up its programing.
Thanks for any help,
Joe
    Master:
  • 763 Answers
Sir this is my solution
try to refresh it by detaching your battery and attach it back. charge it for the time that the battery come in full charge and turn it on. just be sure that your new battery was compatible or not high voltage to accept it on your camera. if not, it must be the hardware inside the camera was broken or damage. hope that helps!
CHARCOIS
Posted on Jul 27, 2008
  • 958 Answers
You can try to put the camera back to the laptop and you may disconnect it before pulling the cable off the computer...
tnx drcool
    Genius:
  • 3,422 Answers
HI,
The battery contacts are dirty.
The batteries are inserted wrongly.
You have a problem with the lens mechanism.
Shake camera and listen for anything rattling around. If metal it could short anything out.
  • 1 more comment
  • Priya darshan Jul 27, 2008
    i suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries.
    you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries..
    ,Polish the terminals with
    a dry cloth and make sure the terminals are clean. If the terminals are
    covered with oil from your skin or similar matter, this may cause poor
    contact and power may not be fully supplied to the camera.
    Also,
    polish the battery charger terminals with a dry cloth before charging
    the battery. If the terminals are covered with oil from your skin or
    similar matter, this may cause poor contact and the battery may not be
    fully charged.
  • Priya darshan Jul 28, 2008
    If
    the lens does not extend then it is possible that it has become jammed.
    Sometimes this can cause the camera to sense an error and shut itself
    down immediately after powering on.There
    are other explanations for the behavior, but if the lens does not move
    this is the most likely cause. If the lens does extend but then the
    camera shuts right back off it is possible that an inner component such
    as the focusing element is not functioning properly.
    IF
    you are not getting a display on your LCD then it is a CCD sensor
    issue.There are no home remedies for this problem and you will have to
    get it repaired.
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Multi indicator light flashes red then green but camera won't turn on - VPC CA8EX
The condition you described is usually a problem with power to the circuit board in Samsung cameras. I know you mentioned the battery but try the following:
1. Ensure battery is good
2. Remove the battery from the camera.
3. Let the camera sit with the battery removed
for approximately 60 minutes.
4. Clean your battery contacts on the battery and in the camera with a clean cloth, or Q-tip dampened with alcohol or contact cleaner.
5. Reinstall the battery and try to power on the camera. If your camera still doesn't work it will need to go in for service.
Dec 30, 2014 | Samsung Video Cameras
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Either while on or off the docking station the tablet itself no longer seems to illuminate or boot up. The battery also flashes a depleted red. I an assuming with A/C power attached this battery shou
please let me help. the ac adapter will plug into the back of the latop.
check lights then if red light still on after one hour plugged in then you need new battery.try this if two green lights only on after, you do not need battery.
you can sometimes find them on ebay...
hope hlps...let me know
May 16, 2009 | ViewSonic ViewPad 1000 Tablet PC
Red flashing light
Find a new supply of "Duracell Ultra with M3 Technology" batteries and give them a try. The flashing red light is usually an indication that the batteries you have in the unit are not producing sufficient power to run the camera. Rechargable batteries are should have a rating of 2500mAh or above in order to provide enough power to maintain the draw from the camera.
Hope this helps!
OpenSource13
Apr 05, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Red power light flashing on and off
the same thing happens to me! idk how to fix it
May 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Kodak md853
I've had my camera for a long time so I don't think I'll get the option of taking it back and exchanging it but I keep having the same charging problem. I just tried the flash button trick... the green light is on, steady, and holding. I'm not going to touch it any more and I hope that if I leave it this way for a bit it'll charge up.
My advice is to NOT LET THE BATTERY RUN DOWN past half charge, otherwise it won't have enough power to stay on long enough to register the fact that its plugged in to the computer.
Oct 18, 2007 | Cameras
Olympus FE-110 Digital Camera Logo
77 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
