Question about Vivitar ViviCam 5385 Digital Camera
Problem with LCD Monitor
I have had no problems with my camera (about 15 mos old) until now. When I power it on to take a picture the screen where my subject is usually focused shows the camera mode information, with a black background, rather than my subject. I cannot take a picture.
  • 2 more comments
  • djmdcarlson Jul 28, 2008
    My camera has been working fine until now. I can turn it on and review what is there, but to take a new picture a blank screen comes up and I am unable to take a picture.
  • Anonymous Aug 28, 2008
    Tried going through all of the settings, but we have lost the manual so are a bit lost.
    without the manual we are a bit lost.
  • podoloamsdow Aug 31, 2008
    My daughters 5385 will power up, but black screen on all settings of the function dial. Camera worked fine until yesterday. It has not been dropped or abused by the owner, as she is very careful of her belongings.
  • 3 Answers
For the initial problem, it sounds like the connection between the image sensor and the rest of the electronics came loose. Not much you can do unless you are comfortable taking the camera apart, and looking for the tiny little ribbon connector that has probably come loose. To get to the image sensor to look for bad connections generally means taking the camera completely apart, not just removing the case. Sorry.
If the camera is 15 months old check and see how you paid for it. Some credit cards offer automatic warranty extension for things bought with the credit card. If the original warranty was a year you might still be covered by an extended warranty if your credit card company does this.
For the people looking for a manual in this thread I found a manual for the 5385 at retrevo.com
Posted on Sep 04, 2008
Posted on Aug 12, 2008
When opening the shutter no image comes up on the LCD screen. The date, remaining image details are still showing however. If a picture is taken, it comes up as a light green screen.
sir,
digital cameras have an image sensor called CCD or C-mos if the camera picture is having problems with color this part may be faulty.
the picture previously taken (before this fault happened) must be fair, if it also bad then there may be problem with LCD or the main board.
Jan 26, 2016 | Cameras
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Over-exposed & Lines Picture problems! Please help!
Kate,
It's six years old - at $90, that represents a mere $15 per annum. Just replace it.
Jun 11, 2017 | Sony Cyber-Shot DSC-H70 Digital Camera
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
I have a samsung 15 inch LCD TV. When I turn the
kcs36dd, Lcd TV's also have, just like LCD monitors, an AC to DC voltage power supply. It is called a "switch-mode-power-supply" and generates the DC voltages required for all the other important electronic circuits inside the unit. 98% of all 14" to 22' lcd panels have backlighting provided by "cold-cathode-fluorescent-lamps" (CCFL) that produce WHITE LIGHT so you can see all the pretty colors that the glass LCD PANEL produces on the screen. The INVERTER circuit requires 12vdc to 20vdc from the SMPS to convert into 500 to 1000v ac to light-up the CCFL's. IF the SMPS detects a FAULT CONDITION with itself or the INVERTER it will go into what is known as FULL or PARTIAL SHUTDOWN MODE to try and save itself from a catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire. lmistyrel on aim.com I could give you more assistance if you had provided following informatiom.
1. How old is the unit? 2, Approximate total "ON" hours unit has? 3.Has unit failed within the WARRANTY period? 4. Will SAMSUNG do a cash+old unit swapout because of PREMATURE FAILURE? 4. Do you know enough to do a unit TEARDOWN and inspection to possibly determine ROOT CAUSE of SMPS/INVERTER failure? 5. Can you handle a soldering iron and solder to make DIY repairs to unit. 6. Since your unit is just a little more complex than a LCD MONITOR, have toy viewed on YOUTUBE short video clips of "LCD monitor disassembly" or "LCD monitor repair" for the most common cause of BLACK screen complaints? If further assistance is required do additional post to original. 12fixlouie aka louie12fix on fixya
Dec 05, 2009 | Samsung 153b-sliver (Silver) 15 in. Flat...
Purple Screen
If it is only 2 months old,then you still have warranty.
A purple lcd, viewfinder and photo is a 100% CCD failure.
If out of warranty, not worth the repair.
Mar 07, 2009 | Panasonic Cameras
LG TV completely dead
I'll think your power supply is down.
Since your tv is 15 month old, you've still got waranty left.
Just contact you supplier or LG service.
Kind regards,
Gerard
Jan 25, 2009 | LG 42LG50 42 in. LCD HDTV
Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
Looking for driver for 15" LCD Television - Model: FLM-1511
Hi Billy. You don't normally need drivers for a monitor of this size. The most common cause of of this problem is that your old monitor was set to a lower resolution than this monitor is designed to support. LCD monitories have a 'native' resolution meaning that the screen itself is made up of 1280 x 768 liquid crystal cells. You need to change the screen resolution to 1280 x 768; assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1280x768 and then click Apply. Post back if you still have the same problem after this.
Aug 09, 2007 | Polaroid 15'' HDTV Monitor FLM-1511
Vivitar ViviCam 5385 Digital Camera Logo
85 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
