Please help blower runs when thermostate is off
  • 828 Answers
Heat cool switch can be in the off position and the fan switch in the on position which can cause this problem. Try putting the fan switch into the automatic position.
Posted on Jul 27, 2008
How to replace thermostate
sounds kind of unclear but my assumption is ure looking for the thermistor which basically makes ure cabin blower work at different speeds and base on that it should always be close to the blower itself by below the dash on the passenger side or near the middle under dash, and maybe even behind glovebox in rare instances, but if u meant thermostat then that should be on the engine compartment by the right side radiator hose assy if looking directly in front of ure car looking to the back.
Dec 30, 2012 | 2005 Saturn Relay
I have a miller mmha-077abhr-05 and it seems I've lost the 24volt side. I can kick the blower on manually with switch in the furnace, but the thermostate seems to be dead, can not get any spark at...
So you have nothing on either side of the transformer (primary or secondary) but the blower will still run?? This means that in between the incoming power, where it first lands in th
Jul 23, 2017 | Heating & Cooling
My furnace and blower wont work but my pilot light is lit
It could be a number of things. Relay, transformer, bad motor, you either need a multimeter with a tiny bit of knowledge in order to track the voltage and find where it is stopping or a professional. Good Luck!!
Apr 30, 2017 | Heating & Cooling
When main switch to heater is turned on, only the flame comes on - no heat or blower. Have tried numerous times to reset by turning main switch off for five minutes, but still does not work. Any...
Does the fan come on when you turn the Fan to ON at the thermostate? If it does then it could be the blower board not turning the low speed blower tap on. Or the Fan & Limit switch not working. If the fan doesn't come on in the on position then the blower motor could be out or the run capacitor.
If the blower comes on it the ON position then you can run the heat with the fan in the ON position till you can get the heat relay looked at.
Dec 21, 2010 | Heating & Cooling
Whirlpool Imperial dryer cyclic thermostate
there is a easyer way to check this put unit back together...put or had on back were vent blows hot exhaust air out...you should feel it get very very hot...then start to cool down..were you could put your had on the vent....if not replaced fixed tsat....please call if need more help..mike..843-384-8474...
Apr 03, 2010 | Whirlpool LER4634J Electric Dryer
Hello , my 2005 Suzuki GSXR 600 , where it normally reads temperature on the dash is saying check temperature but the bike doesn't seem to run hot bc I would definately feel it . I had the computer...
hi buddy its difficult to tell as the thermostate may not be opening a way to tell if this is happening is to get a digital thermostate and put it in the coolant bottle and run it to its normall temperature around 80c the temperature will drop and regain again this has dropped because the thermostate has opened if this doesnt happen then you thermostate has gone if this does wok get back to me buddy
Sep 12, 2009 | 2005 Suzuki GSX-R 600
Hello, thermostate will not stay lit. vacation
Hello, if your going on vacation any way, just shut the power to it off at the breaker box and deal with it later.
Jul 07, 2009 | Fasco Bradford White Hot Water Heater...
Blower runs constantly even with the thermostate off.
There is a fan relay in central air conditioners that can get its contacts welded together and make the fan run all the time. Electronic thermostats can short out and run the fan all the time. Both of these faults require a new part, either a relay or a thermostate.
Jul 26, 2008 | Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
