Question about RIM BlackBerry Curve 8310 Smartphone
The battery life gor my blackberry curve 8310 is simply horrible!!
I've had three battery for it and then I finally requested a new phone. I do use most of the applications like email, texting and the telenav GPS. The telenav I use only in the car and it is always plugged into the car charger. last night I was talking on the phone for 3 hours with in plugged into the charger and it did not charge at all it just didn't sie. I charge the phone 3 to 4 times a day and all night
  • 3 more comments
  • michel967 Sep 27, 2008
    Is there not ay seting to use to make the live longer?I see in the righthand corner that the BB 8310 constantly makes connection when my old one only did it when a e-mail was pushed....
  • jaiitika Dec 29, 2008
    Ive had a blackberry 8320 before and it's battery life was fine. When it was completely charged it lasted me 2 days before it got down to 50 percent. Now that I so called "upgraded" to the 8310 the battery works much less efficiently and I have other problems as well..
  • Anonymous Dec 30, 2008
    **** u alll *****
  • msosa44 Jan 24, 2009
    My CurveĀ“s battery works only about 6 hrs, then kaput, it is gone!!! Any solution?
  • Anonymous May 25, 2009
    My curve has taken to draining to the point of total failure when I am sending a photograph. Otherwise it is fine, though not brilliant. Any suggestions?
I have a Curve too and my battery life has never been longer than 7 hours, I have to bring my charger to work to make it through the day. I am on my second battery too and no improvement. I have also taken off any programs that may **** battery life and its not helping.
Posted on Oct 08, 2008
The true and correct answer is...
All smartphones eat battery power.
The SMARTPHONES that use less power are modles that are limited to doing less applications at the same time.
Acording to RIM and all of the magazines the Blackberries get 4 to 7 hours of talk time without other apps running.
It sounds like you are getting that much talk time.
If you are running aplications like taking pictures or GPS or music then that time drops.
This is normal. This is normal for all smartphones.
I choose a BB Curve 8900 because as well as a keyboard and a screen that can be seen in the sun the curve gets longer battery life than most any other smartphone.
I know this because I read about all of the smartphones on the market and this is one of the best out there for battery life so I have a charger and two batteries to get me through the day and I knew before I bought it that I would still not be able to hike all day with the GPS on or listen to music all day long because smartphones eat power.
Buy a 3rd battery and a out of the phone charger if you want to USE, really use, a smartphone all day.
I use my BB to wake me then tell me where to go then GPS me there then take pictures before and after my work then listen to music while I work.
Your friends that have the all day long I phone are not using it as hard as you are trying to use your BB.
Posted on Mar 18, 2010
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...
Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry Curve 8310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
In need of master security code or puk code for blackberry curve 8310
u need to borrow or use someone elses phone n call t mobils cs help line n tell them u accidentally locked ur sim card n need the puk code, they will tell u wht to do from there n give u the master code as well.
Sep 06, 2012 | AT&T BlackBerry Curve 8310 Cell Phone -...
My blackberry curve 8310 recognises my memory card and says it needs to be formatted but when I go to options, media card and I click on format card nothing happens, the phone doesn't respond and I...
The only time I've see this happen, is when someone uses a memory card that's too large for that model of phone.
That phone can only handle a 4gb max memory card. Anything larger won't work, and can lock up the phone.
Sep 07, 2011 | AT&T BlackBerry Curve 8310 Cell Phone -...
My blackberry curve 8310 is deactivate..how can i activate it again?my phone is from US
Contact your service provider and request for them to reactivate your BlackBerry Internet Service (BIS).
Mar 02, 2011 | RIM BlackBerry Curve 8310 Smartphone
I need the unlock code for my blackberry 8310 imei# 359316010767785
Enter http://blackberrymep.com and request your unlock code, the entire operation will take about 5 minutes .
Sep 26, 2009 | RIM BlackBerry Curve 8310 Smartphone
ATT Blackberry Curve 8310 - new battery drains after 10 hrs - why
is your phone on auto key lock. this helps my phone so that the battery doesnt drain so quickly, ten hours constantly on it is sufficient for a new phone these days
Aug 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
I need my pin2code to enable security on my sim card of my curve 8310
The default PIN code is 0000 on your BlackBerry device. This is for the SIM pin only, and may not refer to any other lock you may have installed on your phone.
If you've forgotten your PIN, simply enter the code incorrectly three times, until PUK blocked shows up on the screen. Call your carrier and get the PUK code, which when correctly entered, will ask for a new PIN code.
If you've forgotten any other password that you've set up, you'll need to have the phone reflashed by a professional.
Jun 26, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310
Try taking the battery out for a minute. Then put it back in...it should reload on it's own.
Mar 31, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve battery problem
buy a battery if problem persists maybe time for a new phone
Jan 24, 2018 | RIM BlackBerry Curve 8310 Smartphone
Problem with my Blackberry Curve 8310
You will need to replace your battery with another one.
Jan 29, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
RIM BlackBerry Curve 8310 Smartphone Logo
1,202 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
