Question about Electrolux Heating & Cooling
Reverse cycle window wall air conditioner. I turn the power on and it is OK when I turn the air conditioner on either manually or with the remote it turns off and trips the main switch. I have tried the trouble shooting in the manual.
  • 143 Answers
Tripping the circuit breaker means that something is shorted out. A fan motor or the compressor, most likely. Disconnect the compressor or turn the thermostat up so high the compressor doesn't start. If the breaker still trips, the fan motor or its capacitor are the problem. If the breaker stays on, the compressor or its capacitor are causing the problem.
Posted on Jul 27, 2008
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Air conditioner repair
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioner Fort Lauderdale
May 25, 2014 | LG LWHD1800R Wall/Window Air Conditioner
The heater is not displayed on the wall remote.
The modern Life., You'll need some how to track it down. However, are the batteries in the remote Fresh? I mean to ask, how old are they? And, are the sensor lenses clear of whatever?
May 02, 2014 | Heating & Cooling
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
No power to air conditioner - Panasonic reverse cycle, CU-A34BBP5
I have read about several of these units having problems with the "Current Detection Boards". It may be dirty and getting loose. You didn't say if the original fuse was bad. Could it be that you need to seat the card again or perhaps clean the contact points?
Hope this helps,
Rich Long
Jan 26, 2014 | Heating & Cooling
Hi, I have a wall mount midea split a/c model- MSG-36HR that will only heat. when put in cool mode it only blow's room temp air and the outdoor unit won't run. On heat mode it works normally. I have cycled...
Most heat pumps are 'fail-safe to heat'. That is: the normal position of the valve which reverses the function is in the position which provides heat. The reversing valve must be powered to switch to the cooling position.
Although the lack of valve function could be a mechanically defective reversing valve - it's more likely to be an electrical issue. Start with checking for power at the reversing valve's coil. If it's powered unpower it - you will be able to hear the reversing valve distinctively
Oct 03, 2009 | Midea Heating & Cooling
We have a fujitsu reverse cycle air conditioner. Last night when we went to turn it off with the remote it did not respond. We needed to turn it off at the switch outside the house. We replaced the...
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Aug 20, 2008 | Fujitsu Heating & Cooling
Manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Jun 08, 2008 | Heating & Cooling
Heating & Cooling Logo
148 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
